Reading: Questions on Level Switches
Inst Tools > Blog > Level Measurement > Questions on Level Switches
Here you can find the common questions on level switches which are used in industrial level detecting applications.
Last updated: February 3, 2021 4:06 pm
Level Measurement Practical Questions
2 Min Read
Vibrating Level Switch
Some level switches use a vibrating rod or paddle to sense the presence of liquids or solids at a specific point.
Vibrating Level SwitchRotating Paddle Level SwitchNuclear Level Switch
Explain how such vibrating level switches work, in as much detail as you can.
Hint: sometimes these switches are known as tuning fork switches if they use two balanced paddles to sense the presence of liquid or solid material.
Also identify potential problems with this type of “point-level” detector caused by improper installation.
Answer
These switches use an electronic circuit to vibrate the rod or paddle, then trigger their output signal upon sensing the dampening of that vibration caused by the presence of liquid or solid immersion.
Potential problems include:
Some level switches use a motor-rotated paddle to sense the presence of solids at a specific point.
Explain how such “rotating paddle” level switches work, in as much detail as you can.
Answer
Level is detected when the paddle (or motor) torque exceeds a pre-set limit.
Potential problems include paddle fouling and seized paddle shaft bearings.
One form of non-contact level switch utilizes nuclear radiation to sense the absence or presence of level within a vessel, either liquid or solid.
Briefly explain how these level switches work.
Answer
Some nuclear level switches work by sensing the blockage of radiation due to process level, others by the “backscattering” (reflection) of radiation by the process level.
Delayed coker drum level detection (in the oil refining industry) is one notable application of the latter technique, where hydrocarbons’ property of reflecting neutron radiation more than other substances is the primary detection characteristic.
Share your answers & explanation with us through the below comments section.
  • Tank Level Switches
  • Float Level Switch Principle
  • Paddle Wheel Level Switch
  • What is a Limit Switch ?
  • Pressure Switch Questions
Credits: Tony R. Kuphaldt
Guided-Wave Radar Instruments Diagnostics
Identify High Flow Alarm and Low Flow Alarm?
Overview of Tank Gauging Technologies
Identify Solenoid Valves Energized or de-energized?
Level Indicators Working Principle
Capacitance Level Measurement Working Principle
Programmable Logic Controller (PLC) Questions and Answers – 9
Sketch a Ladder Diagram for PLC to Energize the Lamp
Basics of DP Transmitter Suppression and Elevation
Level Transmitter Animation
pH Monitoring System Triggers an Alarm
Magnetic Level Indicator
Magnetic Level Indicator Principle, Limitations, Installation and Calibration
Drum Level Compensation of DP Transmitter
Drum Level Compensation and Range Calculation of DP Transmitter
Guided wave radar Measurement Principle
Guided Wave Radar – Principle, Limitations, Installation
Radar and Ultrasonic Level Transmitter Problems Troubleshooting
Radar and Ultrasonic Level Transmitter Practical Problems Troubleshooting
The 5 ways Ultrasonic Sensors Work
Determine Resistance value of Resistors
Thermocouple measurement and reference junction temperatures
Thermocouple Measurement and Reference Junction Temperatures
Twisted Pair Cable Noise Supression
Why We use Shielded Cable and Twisted Pair Cables ?
Download Free HMI software – CODESYS
Interposing Relay Panel (IRP)
thermocouple voltages
Manually Interpreting Thermocouple Voltages
DCS Program to Maintain Draft in Furnace
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
Power Outlet
How does Electrical Power Outlet Work?
PLC Programming for Pumping and Draining System
