Reading: Pulse Timer Instruction in PLC Programming
Inst Tools > Blog > PLC Tutorials > Pulse Timer Instruction in PLC Programming
Last updated: March 4, 2021 1:11 pm
Let’s study the working of pulse timer instruction in Siemens PLC programming.
Pulse Timer in PLCBlock DescriptionPulse Timer:Pulse Extended Timer:Ladder LogicCase 1: When Input set (S) goes ON for the first timeCase 2: When Input set (S) goes OFF before time interval (20s) get elapsedCase 3: When Reset input (R) goes ON before time interval (20s) get elapsed
Pulse Timer in PLC
Pulse Timer in PLC
Block Description
Pulse Timer:
When Timer receives positive pulse at the set input (S), it enables the Q output as long as the preset value set for the timer. The signal change is necessary in order to enable the timer.
Timer will run as long as the input sign (S)  at “1” or accumulator value reaches preset value. The signal state at the output (Q) is at “1” as long as the timer is running. If input (S) changed from “1 to 0” before the time interval has elapsed, timer stopped along with disabling output (Q).
The timer reset input enables to reset the timer while it’s running. Accumulator value backs to zero. Accumulator value can be read at the BI and BCD output of the timer.
The signal state at the output (Q) is at “1” as long as the timer is running. If input (S) changed from “1 to 0” before the time interval has elapsed, timer continue to run and enables output (Q) till accumulator value reach preset value.
Ladder Logic
Network 1:
Input I0.0 is pressed, it gives positive pulse to S input of timer (T0) which makes timer to start running upto 20s ,the time mentioned in the preset value(TV=ST#20s).Output (Q0.0) of timer (T0) enable for 20 s.
Network 2:
Input  I0.2 is pressed, it gives positive pulse to S input of timer (T1) which makes timer to start running upto 20s,the time mentioned in the preset value (TV=ST#20s).Output (Q0.1 )of timer (T1) enable for 20 s.
Pulse Timers in Programmable Logic controllers
Network 1:
Input (I0.0) to the timer (T0) is turned off before the time interval elapsed will make the timer to stop running and output (Q0.0) to go off.
Network 2:
Input (I0.2) to the timer (T1) is turned off before the time interval elapsed will make the timer to continue running and output (Q0.1) to remain ON till the time interval has elapsed.
Pulse Timer (TP)
Network 1:
Reset Input (I0.1) to the timer (T0) is pressed; timer stopped running and disables the output (Q0.0).
Network 2:
Reset Input (I0.3) to the timer (T1) is pressed; timer stopped running and disables the output (Q0.1).
Author: Hema Sundaresan
  • Motor control in Ladder logic
  • Conveyor Ladder Logic Program
  • Function Block Programming
  • Operator Interface for SCADA
  • Control Instructions in PLC
How to use PLC with SQL Database? – Basics & Tutorials
Problem on PLC, HMI, VFD, and Motor Circuit
PLC Program to Control a Water Pump
#3 PLC Best Practices – Leave Operational Logic in the PLC wherever feasible
  • subash says:
    March 2, 2020 at 11:19 am
    Hi,Mdm
    Thank u for a example .its very helpful for me to use ur instruction in my project
Function Blocks in PLC (FBs) – What You Need To Know?
PLC based Door Open and Closing System
Various Causes for PLC Going in Stop Mode
PLC Program to Heat and Bend Glass Tubes
What is the Firmware Version of a PLC? – Siemens PLC Hardware
Label the Electrical Circuit Schematic
Start the Counting from a Preset Value in PLC
Types of Script in Intouch Scada
What is a Network Switch?
PLC Program using Timers
PLC Timers Program
Siemens TIA Portal program blocks
Tia Portal – Optimized and Standard Data Block Access
PLC Timers with Practical Examples
Omron PLC Timer Example Explained
Gas Turbine Temperature Control using Siemens Tia Portal
memory types in siemens plc
#13 PLC Best Practices – Disable Unused Communication Ports
Inclined Water Manometer
How much Pressure is applied to Inclined Water Manometer?
Hazardous Area Terminology
Simple Three Digital Electronic Project Ideas
Test and Electrical Measurement Objective Questions and Answers
100 Test and Electrical Measurement Objective Questions and Answers
Valve Non-rising Stems
Valve Functions and Basic Parts of Valve
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 3
What is an instruction list language?
Structured Text vs. Instruction List for PLC Programming
Pitot tube
Pitot Tube Flowmeter Calculations
