Reading: Proximity Transducer System Operation
Inst Tools > Blog > Vibration Measurement > Proximity Transducer System Operation
Last updated: March 27, 2023 12:40 pm
3 Comments
3 Min Read
Proximity Transducer System provides an output voltage directly proportional to the distance between the probe tip and the observed conductive surface.
 Proximity Transducer SystemVerification of Proximity ProbesProximity Probe Used as a KeyphasorProximity Probes Installation
It is capable of both static (position) and dynamic (vibration) measurements, and is primarily used for vibration and position measurement applications on fluid-film bearing machines, as well as Keyphasor and speed measurement applications.
Proximity Transducer Operation
Proximity Transducer Systems provide an electrical signal that represents the distance between a conductive surface and the probe tip of the system.
The Proximitor contains electronics that provide two functions:
  1. Generate a radio frequency (RF) signal using an oscillator circuit.
  2. Condition the RF signal to extract usable data using a demodulator circuit.
Proximitor Eddy Current Principle
When conductive material is present in the RF field, Eddy Currents flow in the surface of that material.
The penetration depth of the eddy currents depends on the material’s conductivity and permeability. 4140 steel penetration is around 0.003 inches (3 mils).
Proximity Probe Gap Voltage
Once the probe is close enough to cause eddy currents to flow in a conductive material the RF signal is affected in two ways:
1. Amplitude is at a MINIMUM when distance (Gap) between probe and target material (Target) is at a MINIMUM. Maximum eddy current flow occurs.
2. Amplitude is at a MAXIMUM when distance (Gap) between probe and target material is at a MAXIMUM. Minimum eddy current flow occurs.
Vibration Probe Gap Voltage
If the target is moving SLOWLY within the RF field, the signal amplitude INCREASES or DECREASES SLOWLY.
If the target is moving RAPIDLY within the RF field, the signal amplitude INCREASES or DECREASES RAPIDLY.
Oscillatory movement of the target causes the RF signal to modulate.
Vibration Proximitor Demodulator Circuit
The demodulator circuit deals with slowly or rapidly changing signal amplitude in the same way. If the target is not oscillating, as might be the case with a thrust probe, the Proximitor output is a constant DC voltage, called the gap.
If the target is oscillating (gap changing slowly or rapidly) the Proximitors output is a varying DC voltage (AC) shown above by a sine wave. If the probe is observing a vibration, the Proximitor will provide both a DC (gap) and an AC (vibration) component in the output signal.
A typical system frequency response is from 0 Hz (DC) to 10 kHz. Newer transducer systems, such as the 3300XL proximity system have responses up to 12 kHz.
Probe response is verified by measuring and creating a calibration curve.
Problems that can cause proximity probes to be out of tolerance:
  • probe cable length
  • power supply voltage
  • crosstalk and sideview conditions
  • target size and material
Source: Bently Nevada
Articles You May Like :
Inductive Proximity Switch
How Vibration sensors Work?
Vibration Probes Testing
What is TK-3 Calibrator?
What is Keyphasor ? How does Keyphasor works ?
Vibration Switch Working Principle
Why we use Negative Voltage in Vibration Measurement ?
Advantages & Disadvantages of Different Vibration Sensors
Root Cause Analysis for Vibration Probe Not Responding
Gap Voltage of Bently Nevada Vibration Probe
3 Comments
  • Kishan Siddhpura says:
    August 9, 2019 at 11:45 am
    I am reading this article regarding bently Nevada vibration probe and I have doubt regarding proximitor output.
    Suppose my probe is situated in front of rotating shaft in normal operation then it will give DC voltage or AC voltage?
    If probe is sense vibration in shaft then what is change in output signal?
    In that case output will be AC or DC voltage and if it is AC voltage then what is frequency of that output signal?
    So kindly clear my doubts.
    Thank You.
  • Vardhan says:
    August 10, 2019 at 2:13 pm
    Hello Kishan,
    The proximitor transducer will always give the output in DC voltage only.
    You may be seen the eddy currents in the probe which are oscillating and can be termed as A.C. (in milli volts) but this is nothing but change in signal as per vibration (distance between probe and shaft) and this is connected to proximitor which generates required DC voltage.
  • Anil says:
    August 11, 2021 at 3:01 pm
    We are using 330150 sensor and 330180 a proximitor. The output of combination should give -10 V DC at 1.27 mm but we are getting -10V DC at 0.338 mm.
    Why it is happening? We have checked many sensors but giving same.
How Vibration sensors Work ?
What is TK-3 Calibrator ?
Speed Probe Working Principle
AND Logic in Bently Nevada Vibration System
Accelerometer Vibration Probe Principle
Interview Questions on Vibration Measurement
Non-contact Vibration Measurement
Vibration Monitoring System Troubleshooting
Vibration Monitoring System Step by Step Troubleshooting Guide
Seismic Transducers Objective Questions
Vibration Analysis
Top 100 Vibration Analysis Questions and Answers
Bently Nevada 3500 Machinery Protection Systems
Bently Nevada 3500 Machinery Protection Systems Hardware Modules
Basics of Vibration Measurement
Turbine Supervisory Instrumentation
What is Turbine Supervisory Instrumentation (TSI)?
Working of Proximitor
Different Types of Turbine Protective Devices
Installation of Proximitor
Determine Lifting of Shaft using Proximity Sensor
why-lel-important-in-gas-detection
Why LEL important in Gas Detection?
SCADA in Power System
Electrical Energy Management System and SCADA in Power System
2-way solenoid valve Normally Closed
What is a 2-way Solenoid Valve ?
Sump Tank Level Transmitter
Problem with Sump Tank Level Transmitter
Pre-commissioning or Commissioning Activities
U-tube Water Manometer
How much Pressure applied to U-tube Water Manometer?
Control Speed of an Induction Motor using Analog Output of PLC
Control Speed of Induction Motor using Analog Output of PLC
What is a Ultrasonic flow meter
What is a Ultrasonic Flow Meter?
