Reading: Process Control High Level Alarm Fault Analysis
Inst Tools > Blog > Control Systems > Process Control High Level Alarm Fault Analysis
Last updated: October 4, 2019 7:23 pm
Control Systems Practical Questions Process
1 Min Read
An operator reports a high level alarm (LAH-12) displayed at the control room for the last 13 hours of operation, in this sour water stripping tower unit (where sulfide-laden water is “stripped” of sulfur compounds by the addition of hot steam).
Over that time period, the sightglass (level gauge LG-11) has shown the liquid level inside vessel C-406 drifting between 2 feet 5 inches and 2 feet 8 inches:
Process High Level Alarm Example
Click on the Image to Zoom
Identify the likelihood of each specified fault in this process.
Consider each fault one at a time (i.e. no coincidental faults), determining whether or not each fault could independently account for all measurements and symptoms in this process.
Level Transmitter Fault Analysis
Answer :
The below table shows the possible and  Impossible cases for the process high level.
Share Your Answers via Comments
Articles You May Like :
Failsafe Wiring Practices
Difference between PLC & DCS
Process Control Loops
Shutdown Philosophy
Fire & Gas system Alarm
Thermocouple Measurement and Reference Junction Temperatures
Override Control Functions
Process Dynamics and PID Controller Tuning
Motor Control Center (MCC) Signal Interface Termination (SIT)
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
How to Stop Cyber Attacks on PLC or DCS?
PID Simulator Download
What is Timeout in Communication Protocols?
Hardwired I/O and Serial I/O – Differences Explained
Calculate the appropriate millivoltage values of a Thermocouple
Pneumatic Moment-balance Differential Pressure Transmitter
What is a Recorder ?
How does a Redundant Controller comes in line when the Main Controller fails?
Bucket Steam Trap
Bucket Steam Trap
Difference Between PNP and NPN Sensors
Process Shutdown
Difference between Process shutdown and Emergency Shutdown
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
Limit Switches Wiring
Draw Limit Switch Symbol ?
Pitot tube
Pitot Tube Flowmeter Calculations
Signal Strength of Guided-wave Radar Level Instrument
Distributed Control System & Motor Control Center Interface Philosophy
Recurring Short Circuit Flash Overs Safety Hazards
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Charging Currents in Transmission Lines
2 wire transmitter current loops
PLC Program for Analog Input Sampling
PLC Analog Input Sampling Ladder Logic
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
Electricity and Magnetism Questions & Answers
Top 300 Electricity and Magnetism Questions & Answers
Types of Can Open network topologies
CANOpen Network Topology
