Reading: Self-Actuated Valves, Pneumatic & Hydraulic Actuators
Inst Tools > Blog > Control Valves > Self-Actuated Valves, Pneumatic & Hydraulic Actuators
Last updated: March 21, 2019 3:26 pm
Control Valves
2 Min Read
Pneumatic actuators as illustrated in Figure, provide for automatic or semiautomatic valve operation. These actuators translate an air signal into valve stem motion by air pressure acting on a diaphragm or piston connected to the stem.
Self-Actuated Valves, Pneumatic & Hydraulic ActuatorsHydraulic ActuatorsSelf-Actuated Valves
Pneumatic actuators are used in throttle valves for open-close positioning where fast action is required. When air pressure closes the valve and spring action opens the valve, the actuator is termed direct-acting.
When air pressure opens the valve and spring action closes the valve, the actuator is termed reverse-acting. Duplex actuators have air supplied to both sides of the diaphragm.
The differential pressure across the diaphragm positions the valve stem. Automatic operation is provided when the air signals are automatically controlled by circuitry. Semi-automatic operation is provided by manual switches in the circuitry to the air control valves.
Figure  Pneumatic Actuator
Hydraulic Actuators
Hydraulic actuators provide for semi-automatic or automatic positioning of the valve, similar to the pneumatic actuators. These actuators use a piston to convert a signal pressure into valve stem motion.
Hydraulic fluid is fed to either side of the piston while the other side is drained or bled. Water or oil is used as the hydraulic fluid.
Solenoid valves are typically used for automatic control of the hydraulic fluid to direct either opening or closing of the valve. Manual valves can also be used for controlling the hydraulic fluid; thus providing semi-automatic operation.
Self-actuated valves use the system fluid to position the valve. Relief valves, safety valves, check valves, and steam traps are examples of self-actuated valves.
All of these valves use some characteristic of the system fluid to actuate the valve. No source of power outside the system fluid energy is necessary for operation of these valves.
Articles You May Like :
Types of Valve Actuators
Snap Acting Relay Principle
Pneumatic Valve Positioner
Control Valve Packing
Double Acting Actuators
What is Travel Stop in Control Valve?
Difference between Pneumatic, Electrical & Hydraulic Actuators
Control Valve Passing Problem after Overhauling Job
Control Valve Positioners
Solenoid Valves Practical Problems
Problem with Choked Control Valve with Whisper Trim Cage
  • Good luck Joseph says:
    December 1, 2020 at 4:03 am
    Please sir,, where actuator valve can be fined in Lagos State Nigeria,I need the address of the location of the place if any other place I need to know now thank you.
How to Do Maintenance of Control Valve Which is Stuck in Field?
Calculate Flow Coefficient Kv of Solenoid Valve
Four Way Solenoid Valve Working Principle
Fundamentals of Valves and their Types
Solenoid Valve Troubleshooting Tips
Control Valve Parts Questions and Answers
Pressure to Current (P/I) Converter Principle
Working Principle of Hydraulic Actuators
Air Cylinder Consumption Calculation for Control Valves
Metal Seated Ball Valves
Metal Seated Valves and Soft Seated Valves : Differences
Control Valves Classification
Classification of Control Valves
What is Pump Cavitation
What is Pump Cavitation? How to Avoid Cavitation?
Valve Seat leakage Test
Valve Seat Leakage Test
Dual Solenoid Valve on Control Valve
Why we Require Dual SOV on a Control Valve?
Valve Face to Face Dimension
Face to Face Dimension of Control Valve
Real-time and historical SCADA Trends
What are Trends in SCADA?
Non-Contacting-Radar-Level-Transmitter-Animation
Non Contacting Radar Level Transmitter Animation
Self Balancing Potentiometer Objective Questions
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Choppers Quiz
Difference Between Emergency STOP and Emergency Power OFF
Insulating Material for Cable Requirements
Transmitter Identification Codes
Instrument Identification Tags
