Reading: PLC Pump Control: 10 seconds ON & 20 seconds OFF
Inst Tools > Blog > PLC Tutorials > PLC Pump Control: 10 seconds ON & 20 seconds OFF
Design a program for PLC pump control such that the pump must be turned ON for 10 seconds and turned OFF for 20 seconds.
Last updated: April 8, 2024 3:38 pm
PLC Pump ControlExpert PLC TrainingInputsOutputsPump Run for 10 seconds & OFF for 20 seconds LogicProgram DescriptionPLC Program Result
Note: The plc programming example is prepared for the engineers who are interested in learning the ladder logic with basics.
PLC Pump Control
Problem Statement:
We are using one toggle switch to control the pump.
Turn ON the pump for 10 seconds and then turn OFF the pump for 20 seconds and repeat this cycle.
Expert PLC Training
Our PLC training videos explain the basic concepts and PLC programming for beginners with detailed explanations.
PLC Programming for Pump Running Cycle with Time Delay
Inputs
The required input is listed below.
Start button: I0.0
Outputs
The required output is listed below.
Pump: Q0.0
PLC Pump Control
Program Description
We used Normally Open Contact for the Start button.
Two Timer Function Blocks Type TON and TP are used for the Pump and memory bit.
Timer Function Block type TP is used to keep the Pump ON for 10 seconds.
Timer Function Block type TON is used for the Memory bit to turn it ON after a delay of 20 seconds.
PLC Program Result
When the Start button is turned ON, the signal will flow also through the Normally Closed Contact that is used for memory bit as it is false state. Timer functional block type TP (TM0) will allow the signal to flow for a period of 10 seconds only.
PLC Programming Example on Pump Cycling
As a result, the pump will be turned ON. After 10 seconds, the signal will not flow because of the Timer functional block type TP (TM0). And pump will turn OFF after being ON for 10 seconds.
When the Start button is turned ON and when the pump gets turned OFF after being ON for 10 seconds, the signal will flow through the Normally Closed contact used for PUMP. There will be a delay of 20 seconds and after that memory bit gets true. In those 20 seconds, the motor will remain OFF.
After a delay of 20 seconds, the coil used for the memory bit becomes true, and the Normally Closed Contact used for the Memory Bit will also become true. The Normally Closed Contact in its true state will break the circuit.
As a result, the coil used for the coil memory bit becomes false which in turn makes the Normally Closed Contact used for the memory bit false. And the signal will again pass to the pump and it will be turned ON for 10 seconds. After that, it will remain OFF for 20 seconds and then it will repeat the process again and again.
How PLC is used for timed switch operations
  • PLC Programming Example with Motor
  • PLC Push Button to Turn ON or OFF Output
  • PLC Code to Start & Stop Motor and Pump
  • Electrical Ladder Diagram Control with Timers
  • Controlling the PLC Output using Push Buttons
Advanced PLC Conveyor Control: Forward and Reverse Rotation
PLC Program Examples
Schneider PLC Example: Control Lamps Sequences
Basic PLC Ladder Programming Example
PLC Multiple Outputs Configuration
Down Counter PLC Program
PLC Program for Ceramic Burning Oven Conveyor System
PLC Techniques for I/O Mapping
V1000 Family Programming Simulator Tool
Redundant system communication cable
What is Interface Module in Siemens PLC?
Automatic Box Filling System using PLC Programming
FIFO and LIFO Sequences in PLC
What are FIFO and LIFO Sequences in PLC?
Create Ladder Diagram from Boolean Logic
Preventa XPS MC, XPS MP - Safety controllers
High-end Programmable Logic Controller – Schneider PLC
Communicate between the PLC program and HMI program
Design a Program Using Studio 5000 and FactoryTalk View Studio
Different Control Modes of Air Handling Unit (AHU)
Control Modes of Air Handling Unit (AHU) – HVAC Basics
Installation and Maintenance of Control Valves
User Defined Data Types - UDT
User Defined Data Types (UDT) – Purpose, Need, Tutorial
What is a Rotary Actuator
Difference Between Linear Actuator and Rotary Actuator
Understanding RS-485 Communication
Power Triangle
Apparent Power, True Power, Reactive Power & Total Power
How to Update the Firmware Version of your PLC
How to Update the Firmware Version of your PLC? – TIA Portal
Why is IGBT used in VFD
Why is IGBT used in VFD?
