Reading: Five Types of PLC Programming languages
Inst Tools > Blog > PLC Tutorials > Five Types of PLC Programming languages
Five types of PLC programming languages : Ladder Diagram, Structured Text, Instruction List, Function Block Diagram and Sequential Function Chart.
Last updated: November 2, 2023 4:43 pm
3 Min Read
Although it seems each model of PLC has its own idiosyncratic standard for programming, there does exist an international standard for controller programming that most PLC manufacturers at least attempt to conform to. This is the IEC 61131-3 standard, which will be the standard
One should take solace in the fact that despite differences in the details of PLC programming from one manufacturer to another and from one model to another, the basic principles are largely the same.
There exist much greater disparities between different general-purpose programming languages (e.g. C/C++, BASIC, FORTRAN, Pascal, Java, Ada, etc.) than between the programming languages supported by different PLCs, and this fact does not prevent computer programmers from being “multilingual.”
I have personally written and/or analyzed programs for over a half-dozen different manufacturers of PLCs (Allen-Bradley, Siemens, Square D, Koyo, Fanuc, Moore Products APACS and QUADLOG, and Modicon), with multiple PLC models within most of those brands, and I can tell you the differences in programming conventions are largely insignificant.
After learning how to program one model of PLC, it is quite easy to adapt to programming other makes and models of PLC.
The IEC 61131-3 standard specifies five distinct forms of programming language for industrial controllers:
  • Ladder Diagram (LD)
  • Structured Text (ST)
  • Instruction List (IL)
  • Function Block Diagram (FBD)
  • Sequential Function Chart (SFC)
Not all programmable logic controllers support all five language types, but nearly all of them support Ladder Diagram (LD), which will be the primary focus of this book.
Programming languages for many industrial devices are limited by design.
One reason for this is simplicity: any programming language simple enough in structure for someone with no formal computer programming knowledge to understand is going to be limited in its capabilities.
Another reason for programming limitations is safety: the more flexible and unbounded a programming language is, the more potential there will be to unintentionally create complicated “run-time” errors when programming.
The ISA safety standard number 84 classifies industrial programming languages as either Fixed Programming Languages (FPL), Limited Variability Languages (LVL), or Full Variability Languages (FVL).
Ladder Diagram and Function Block Diagram programming are both considered to be “limited variability” languages, whereas Instruction List (and traditional computer programming languages such as C/C++, FORTRAN, BASIC, etc.) are considered “full variability” languages with all the attendant potential for complex errors.
  • PLC Important Questions and Answers
  • What is Ladder Diagram Programming ?
  • Introduction to Microprocessor Programming
  • SAVE and BR Memory Instructions in Siemens PLC
PLC Programming Example on Timers Function Block
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
#6 PLC Best Practices – Validate Timers and Counters
Automatic Box Filling System using PLC Programming
Industrial Oven Control Application with PLC Controller
Basic PLC Ladder Programming Example
How to Solve Electrical Ground Loop Problems?
Siemens micro memory card
Micro Memory Card (MMC) in Siemens PLC
DDE Protocol
What is the DDE Protocol?
PLC Program for Alarm Indication in Process
PLC Ladder Logic Questions and Answers
Difference Between PLC and CNC Machine
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
How-to do Security of SCADA Systems
How-to do Security of SCADA Systems?
Energy Meter Data in PLC using Modbus Communication
Modbus Communication between PLC and Energy Meter
S84 - IEC 61511 Standard for Safety Instrumented Systems
S84 / IEC 61511 Standard for Safety Instrumented Systems
Intrinsic Safety of Instruments
Redundant Power Supply
How Does Redundant Power Supply Work?
Target Flow Transmitter Problem
Unreliable Ammonia Flow Transmitter Reading and Problems
Asynchronous Counter Objective Questions
how-to-find-resistor-value
Limitations of Resistors
Different Control Modes of Air Handling Unit (AHU)
Control Modes of Air Handling Unit (AHU) – HVAC Basics
