Reading: PLC Program for Water Level Control Logic
Inst Tools > Blog > PLC Tutorials > PLC Program for Water Level Control Logic
Design a PLC program for water level control of a storage tank by turning a discharge pump ON and OFF based on Level Switch status.
Last updated: November 2, 2023 4:46 pm
4 Comments
2 Min Read
Design a PLC program to control the level of a water storage tank by turning a discharge pump ON and OFF based on Low and High levels.
PLC Program for Water Level ControlLogic DescriptionPLC Ladder LogicManual Mode Selected, OFF Position and Water at Low LevelManual Mode Selected & Water between Low & High LevelsAuto Mode Selected & High-Level Switch Activated
Ladder Logic for Water Level Control
Logic Description
  • Auto : if Auto Mode selected in Local Control Panel, then pump will be logically controlled based on Low Level Switch and High Level Switch
  • Manual : if Manual Mode Selected in Local Control Panel, then irrespective of Low Level Switch & High Level Switch Status, Pump will be controlled manually using ON/OFF button in Local Control Panel.
  • When the water level reaches low level then pump will be stopped.
  • if the level of the water reaches high point, the pump will started so that the water can be drained and thus lowering the level.
  • Indication Panel : This panel contains LED’s to show the status of the water level control. It has Pump Running, Low Level & High Level Signals
  • If pump is running then the Pump Running status lamp will be ON.
  • then, if Low Level Switch activated then Low Level Status lamp will be ON.
  • if High Level Switch activated then High Level Status lamp will be ON.
PLC Ladder Logic
PLC Water Level Logic
Water Level Control using PLC
Level Control PLC Logic
  • Process Control Fundamentals
  • Mixing Tank PLC Ladder Logic
  • Automation Engineers Questions
  • Fan Control Unit System using PLC
  • PLC Electric Motor Interlocks
Single-Acting Cylinder Control using Proximity Sensor
3 Phase Motor Control using PLC Ladder Logic
SCADA Multiple Choice Questions
PLC based Auto/Manual Operation of Roll down Shutters in Industry
4 Comments
  • kingsley says:
    June 29, 2017 at 10:54 am
    SIR, YOUR ARTICLES ARE SUPERB YOU ARE GREAT!!! THANKS A MILLION!!
  • Dharmesh Kavaiya says:
    July 6, 2017 at 10:40 am
    Hi Sir
    Thanks a lot for such a valuable details and information.
    I have also started youtube channel to learn Industrial Automation technologies like PLC,SCADA, DCS, HMI, IOT, VFD and process Instrumentation.
    Please watch my channel “Automation Revolution” and if possible embed my video in your blog.
  • Pritam Shet says:
    March 9, 2021 at 11:07 pm
    Motor not starting when sensors dipped in water,
    When sensors are directly connected motor starts? Whats the problem?
  • Agamah Godwin says:
    August 13, 2021 at 3:53 pm
    please which web site or link can I use ladder logic diagram for my project reference
PLC based Gas Detection System using Ladder Logic Project
Tia Portal – OB10 Time of Day Interrupt Organization Block
PLC Emergency Stop Example Program
Two Hand Control Logic using PLC
How to use JUMP Instruction in PLC Ladder Logic?
PLC Connection between Instrument, Junction Box, Marshalling & System Cabinet
Standard Colors in PLC Automation Systems
Difference Between Normal Counters and Fast Counters – Learn PLC
Surge Protection Device
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
Opposite Acting Control Valves Application
PLC Ladder Logic for Opposite Acting Control Valves Application
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
Free Mitsubishi PLC Online Training Courses
Free Mitsubishi PLC Online Training Course and Tutorials
Causes of PLC Stop Mode
Various Causes for PLC Going in Stop Mode
SCADA Software and their Comparison
Auto Sugar Bag Filling Station
Calculate Power in Parallel RL Circuit
What is a Spool valve
What is a Spool Valve? – Types, Configurations, Applications
HMI book
HMI Handbook
Digital Instrument Example
Digital Measuring Instruments – Types, Functions, Advantages, Disadvantages
Coriolis Flow Meter Inaccuracy
Coriolis Flow Meter Uncertainty and Inaccuracy
Difference Between Adhesion and Cohesion
Optimal Control Systems
Output Regulator & the Tracking Problem
3 Phase Balanced Loads
Power in Balanced 3 Phase Loads
