Reading: PLC Logic GATE Program
Inst Tools > Blog > PLC Tutorials > PLC Logic GATE Program
PLC Logic GATE : Write a PLC Ladder logic for AND gate, OR gate, NOT gate and XOR agte. Explore PLC tutorials for beginners pdf guide.
Last updated: November 2, 2023 5:00 pm
1 Min Read
Write a PLC Logic GATE Program for the below plc example.
Logic GATE ProgramPLC Ladder Logic
Logic GATE Program
Write a program that ANDs B3:0 with B3:1 when I:0.0/0 is energized, ORs B3:0 with B3:1 when I:0.0/1 is energized, XORs B3:0 with B3:1 when I:0.0/2 is energized and COMPLEMENTS B3:0 when I:0.0/3 is energized. B3:1 is to hold the result in each case.
If more than one input I:0.0/0-I:0.0/3 is energized, only one of the operations will be performed.
The precedence order for operations should be from AND (highest precedence) to COMPLEMENT (lowest precedence).
PLC Ladder Logic
PLC Logic GATE
You can share a detailed explanation of the above PLC ladder logic in the comments section.
Author: Dr. D. J. Jackson
  • Two Way Switch Logic using PLC
  • PLC Counting Objects on Conveyor
  • PLC Program for Paint Spraying
  • How to Draw a Schematic Diagram?
  • Analyze the Relay Circuit Status
Introduction to PLC – Advantages of PLC
Batch Mixing with PLC Ladder Logic Program
Studio 5000: Define Program or Operator Control in Functional Block Diagram
SAVE and BR Memory Instructions in Siemens PLC Programming
Types of Industrial Control Systems
How to Configure PID Controller in Various Schneider PLCs?
PLC Program for Controlling Sequence of Conveyors with Interlock
Siemens PLC Organization Blocks (OB)
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
Download a Ladder logic program to GE PLC
Top PLC Manufacturers
Automatic Packing of Bottles Programming
Industrial motor control using PLC instruction list programming
PLC Instruction List for Motor Reverse and Forward Direction
Function of Racks in PLC System
Function of Racks in PLC – Types of SIEMENS S7-400 PLC Racks
Laws of Boolean Algebra using Ladder Logic
DCS
DCS
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Batch mixing process automation with Omron PLC
Automate Batch Mixing with Repeated Cycles in Omron PLC
PLC Sequential Lights Control Example
PLC Timer Example: Sequential Control of Three Lights with Reset
Components of PLC
Digital Electronics Objective Questions – Set 2
Retentive ON delay timer using PLC Logic
Retentive ON Delay Timer using PLC
Best PLC for Your Project
Finding the Best PLC for Your Project – Tips and Tricks
Electric-driven Air Compressor Troubleshooting
Plant Air Storage Tank
Difference between Analog Signal and Digital Signal
Quiz on Electrical Meters and Measurement
200+ Quiz on Electrical Meters, Measurement, and Troubleshooting
How to do Turbine Flow Meter Verification?
