Reading: PLC Counters Program
Inst Tools > Blog > PLC Tutorials > PLC Counters Program
Write a PLC counters program application. we discuss PLC counters ladder logic practice problems and solutions of programmable logic controllers.
Last updated: November 2, 2023 4:59 pm
2 Min Read
Write a PLC Counters Program for the below example.
PLC CountersPLC Logic
PLC Counters
A certain process is to count the number of true-to-false transitions on input I:0.0/0 for a 10 second period.
Counting is to occur if input word I:0.1 has a value less than 10000 or greater than 20000.
The 10 second counting period is to begin 15 seconds after the process starts. I:0.0/1 is a process start input and input I:0.0/2 is a process stop input.
The count display is to be output to word O:0.0 only at the end of the count period.
All outputs are to be de-energized 5 seconds after the count period.
The process should repeat only after another distinct press of the process start input.
Write an efficient ladder logic program for this process.
PLC Logic
You can share a detailed explanation of above PLC ladder logic in the comments section.
Author: Dr. D. J. Jackson
  • Two out of Three Logic Analogy
  • How PLC Controls a Motor?
  • PLC Program using Logic GATE
  • Engineering Logic Diagrams
  • PLC Conveyor Ladder Logic
  • PLC Program for Blinking Lamp
Step-by-Step Guide to Choose Right Fuse for a Panel
Bread Oven Control in Auto and Manual Modes PLC Program
Split Range Control Application using PLC Ladder Logic
Types of Interlocks
PLC FBD Example for Tank Liquid Heating Control by Steam Flow
PLC Analog Signals Wiring Techniques
Getting to Know the LED Indications on GE Make PLC
Tia Portal – OB121 Programming Errors Interrupt Organization Block
How to use Masked Move Instruction in PLC
Augmented Reality and Virtual Reality in Industrial Automation
Types of Script in Intouch Scada
EasyBuilder Pro Weintek HMI Software
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
21 CFR in SCADA and HMI Systems
What is 21 CFR in SCADA and HMI Systems?
User Defined Function Blocks in PLC
What are User Defined Function Blocks in PLC?
PLC Programming Example with Pushbutton and Motor
TON Timer in RSlogix
Why is RTO used in the Place of TON Timer?
Put Get PLC communication
PUT Command in Siemens PLC – TIA Portal Basics
User Defined Data Types - UDT
User Defined Data Types (UDT) – Purpose, Need, Tutorial
Siemens Industrial Laptop (Simatic Field PG)
Connect to the Siemens S7 PLC
Difference Between LDR and Photodiode
Stability in Frequency Domain
Tuning of PID Controllers
The Control Valve Stroke Test Procedure
plc-analog-input-card-conversion-formula
Electrical Machines MCQ Series 4
Single-Phase Half Wave AC-DC Converter Quiz
Advantages & Disadvantages of AC power and DC power
Air Lock Relay Working Principle
Control Valve Air Lock Relay Working Principle
