Reading: PLC Program to Drain Same Products from Two Tanks
Inst Tools > Blog > PLC Tutorials > PLC Program to Drain Same Products from Two Tanks
This is a PLC Program to drain the same products from two tanks. Learn the PLC programming with this simple example.
Last updated: November 3, 2023 12:10 pm
Drain the Same Products from Two TanksProblem DiagramPLC Example SolutionList of I/OsPLC Ladder Diagram for draining the same products from two tanksProgram ExplanationResult
Problem Description
Two tanks are filled with same products. Draining materials from these two tanks is depended on the requirement of storage tank.
Implement logic for this system in PLC using ladder diagram.
Problem Diagram
Here two tanks are used for the system. For level measurement, two sensors are used (level low sensors). As shown in figure we use here two pumps for transferring the materials from tanks (Tank 1 & Tank 2) to storage tanks.
Here we will use level transmitter for storage tank level measurement. PUMP 1 & PUMP 2 will be controlled by level transmitter feedback.
Here we used two pumps for smooth operation. Both pumps will be operated when level of the storage tanks is detected below its limit.
Note:-Here we are consider simple automation for this system. Level transmitter is used in this system and it will measure the level of the storage.
Storage tank is taken of 500cm height for simplicity and level transmitter feedback is 4 to 20mA.
We will use PLC S7-300 for this application. We will use scaling for programming purpose.
List of I/Os
List of inputs
  • Cycle START:- I0.0
  • Cycle STOP :- I0.1
  • Level low of tank 1 :- I0.2
  • Level of tank 2 :- I0.3
List of outputs
  • Pump 1 :- Q0.0
  • Pump 2 :- Q0.1
M memory
  • Cycle ON bit :- M0.0
  • Analog value from the transmitter :- MW10 (INT)
  • Analog value from the transmitter :- MD100 (DINT)
  • Multiplication value :- MD104
  • Actual water level (cm) :- MD108
Ladder Logic for draining same products from two tanks
analog value from the transmitter
fill storage tank pump
PLC Pump ON
PLC Drain Pump
Program Explanation
For this application, we used S7-300 PLC and TIA portal software for programming.
Network 1:
we used latching circuit for cycle ON (M0.0) output.it can be started by pressing START PB (I0.0) and stop by pressing STOP PB (I0.1).
Network 2:
Here actual count or value coming from the transmitter is current (4 to 20mA) so by using analog input channel in the PLC we can convert it into digital count. This digit is in INT (MW10) format so we need to convert it into DINT (MD100) for calculation or multiplication.
Network 3:
DINT value (MD100) is multiplied with max height (500cm) of the tank for calculation purpose.
Network 4:
Multiplied value (MD104) is divided by max count of the analog module (27648).And final actual height is stored in MD108.
Network 5:
Here we used comparator for PUMP 1 (Q0.0).During requirement of the material PUMP 3 will be operated by operator, water level height will decrease.
So as per our automation or system we need to fill storage tank, pump 1 will be started if water level is less than its limit (here we have taken 480cm).
Note:- PUMP 1 should be stop if level low (I0.2) of the tank 1 is detected.
Network 6:
Here we used comparator for PUMP 2 (Q0.1). During requirement of the material PUMP 3 will be operated by operator, water level height will decrease. So as per our automation or system we need to fill storage tank, pump 2 will be started if water level is less than its limit (here we have taken 480cm).
Note:- PUMP 2 should be stop if level low (I0.3) of the tank 2 is detected.
During all function cycle should be ON.
Note:- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of drainage system, we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications. Also all interlocks are not considered in the application.
Result
PLC Logic to Drain Same Products from Two Tanks
Author: Bhavesh
  • PLC Timer Instructions
  • Ladder Logic Questions & Answers
  • Contacts and coils
  • PLC Analog Input Scaling
  • PLC Example with Switches
PLC Sequence Programming Ladder Logic
PLC Automatic Irrigation System
3 Phase Motor Control using PLC Ladder Logic
PLC Pump Permissive Interlocks
Rockwell PLCs for Large Scale Applications
What is an Instruction List? – PLC Programming
STAR DELTA Programming using PLC Controller
PLC Program for Entry and Exit Control of Car Parking
How Does Redundant Power Supply Work?
Mail Box Automation: Programming with Schneider PLC
Power Supply Sizing for Industrial Automation Systems
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
HMI Screen Design for Hazardous Applications
PLC Conversion Program
How to use Converters in PLC
D flip flop in PLC
D Flip Flop PLC Ladder Logic
Interposing Relay Panel (IRP)
PID Simulator
PID Simulator Download
how-a-4-20ma-transmitter-works
How a 4-20mA Transmitter Works?
Multi-Tank Liquid Level Control System with Fill Priority [PLC]
Twisted Pair Cable Noise Supression
Why We use Shielded Cable and Twisted Pair Cables ?
W Type Transit Time Flow Meter
Transit Time Flow Meter – Types, Advantages, Disadvantages
Functions of Instrument Transformers
Functions of Instrument Transformers (CTs and PTs)
Up Down Counter Objective Questions
Displacer Level Measurement Formula
Displacer Level Measurement Calculations
Current to percentage conversion
Convert current (4-20mA) to Percentage (0-100%)
Function Block Program Simulation
SCADA Standards
SCADA for Substation Automation
