Reading: PLC Conveyor Ladder Logic Program
Inst Tools > Blog > PLC Tutorials > PLC Conveyor Ladder Logic Program
Basics of PLC Programming and examples. Design a PLC Conveyor Ladder Logic Program. Parts are to advance along the conveyor.
Last updated: November 3, 2023 9:44 am
2 Min Read
Assume there are sixteen stations along a conveyor system.
The stations are numbered from 0-15 with station zero being the first (i.e. the point where parts enter the conveyor).
Parts are to advance along the conveyor at the rate of one station every four seconds.
A part may or may not be at a given station at any point in time.
An input sensor I:0.0/0 is used to detect a part entering the conveyor.
At station 5, parts are checked for defects and an input sensor I:0.0/1 is energized if the part is defective.
At station 10, any defective parts are to be removed from the conveyor by energizing output O:0.0/0.
Write an efficient ladder logic program for this process.
You can share the detailed explanation of above PLC ladder logic with comments section.
Author: Dr. D. J. Jackson
  • Programmable Logic Controllers MCQ
  • PLC Programming Questions & Answers
  • Basics of PLC Programming Videos
  • PLC Controlling Sequence of Conveyors
  • How to Draw a Schematic Diagram?
PID Block in RSLogix 500
Mail Box Automation: Programming with Schneider PLC
Tia Portal – OB10 Time of Day Interrupt Organization Block
PLC based Gas Detection System using Ladder Logic Project
What is a PLC? – Programmable Logic Controller
Difference between DCS, PLC, and RTU ?
PLC Logic for Automatic Bending Machine for Exhaust Pipe
How to Password Protect HMI in Siemens TIA Portal?
PLC Program for Flow Totalizer
SCADA Hardware and Software
Motor Speed Control using VFD and PLC Programming
How to Connect a Solenoid Valve with PLC?
Comparison Instructions in PLC Programming
Free Schneider PLC Training - Automation Course
Free Schneider PLC Training – Automation Course
PLC Tag Naming Conventions
Siemens Profibus Interface DP
How to Create New Project Using Simatic Manager
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
PLC Ladder Program for Automatic Car Wash
PLC Ladder Program for Automatic Car Wash using Siemens TIA Portal
Classification of Fuses
Step-by-Step Guide to Choose Right Fuse for a Panel
ON and OFF a Group of Outputs by One Push button PLC Logic
Flash Vessel All Level Instruments Stopped Working
Ammonia Flash Vessel All Level Instruments Stopped Working
Electrical & Electronics Measurements Objective Questions – Set 1
30 Concerns for Control System Philosophy (Industrial Automation)
pressure transmitter calibration setup
Why Pressure Vessel Connected to Tubing System?
Omron PLC Car Parking Program
Career Opportunities in Instrumentation Engineering
Job and Career Opportunities in Instrumentation Engineering
Power Electronics Diode Circuits Questions and Answers
Nuclear Plant Sensors and Detectors Quiz
