Reading: PLC Program for Alarm Security System
Inst Tools > Blog > PLC Tutorials > PLC Program for Alarm Security System
This is the PLC Program for Alarm Security Systems. Learn the PLC programming with this example problem.
Last updated: November 3, 2023 11:58 am
Alarm Security SystemProblem DiagramProblem SolutionList of Inputs and OutputsPLC Ladder Diagram for Alarm Security SystemProgram DescriptionResult
Problem Description
Make burglar alarm system program in S7-1200 PLC for the house.
Consider one house, in this we want to arrange automatic burglar alarm security system. Alarm should be ON when any person will be detected by the motion sensor.
Problem Diagram
PLC Program for Burglar Alarm Security System
Problem Solution
We can solve this problem by using simple logic. Here we can use two sensors, one motion sensor and second window sensor. Window sensor is the loop of wires.
The motion sensor is designed such that when person is detected in a house or room, then the sensor will be activated (change its state to 1 or true)
Here important point in window sensor is that current is always passing until the breakage occurs in the glass. Hence output always true and when someone will try to break the window glass, current will not flow in the circuit.
Inputs List
  • System START :- I0.0
  • System STOP :- I0.1
  • Motion detector :- I0.2
  • Window sensor :- I0.3
  • Alarm stop button :- I0.4
Outputs List
  • Alarm :- Q0.0
M Memory
  • M0.0 :- Master coil.
  • M0.1 :- Alarm on condition.
PLC Logic for Alarm Security Systems
PLC Alarm System
PLC Burglar System
Program Description
In this problem we will consider S7-1200 PLC and TIA portal software for programming.
Network 1:
This network shows simple latching circuit for system ON and system OFF.
we used Normally Open (NO) contact of system START button (I0.0) and NC contact of system STOP button (I0.1) for system activation.
Network 2:
When system is activate and motion sensor (I0.2) detects the person entry, alarm on (M0.1) condition will be ON and it will activate the alarm (Q0.0).
Normally NC contact of window sensor (I0.3) is used in parallel so in normal condition it is true. If breakage of glass or window condition is detected, window sensor (I0.3) input goes false and it will activate the alarm condition (M0.1).
Network 3:
In this network latching circuit is used for alarm (Q0.0). If alarm condition is detected (M0.1), alarm will be ON and it can be stopped by pressing alarm STOP PB (I0.4).
Note :- Above logic is for explanation purpose only. We can implement this example by using hard wired relay logic also. S7-1200 PLC system is so costly for this simple system.
Result
PLC based Security System
Author: Bhavesh
  • PLC Program for Motor Starter
  • Analog Input Sampling in PLC
  • Positive Edge Output for One Cycle
  • Automatic Liquid Mixing Application
  • PLC Program START & STOP Buttons
#13 PLC Best Practices – Disable Unused Communication Ports
How to Read the PLC Datasheet? – Important Notes About PLC
Comparison of Proportional Integral Derivative Controllers (PID)
Create an Application in HMI using Tia Portal
PLC Program for Two Way Switch Logic
Sorting & Distribution Line PLC Programming – Advanced Logic
Structured Text vs. Instruction List for PLC Programming
Learn PLC in Hindi
What is a Tag? Types of Tags in SCADA
Siemens HMI Training – Using UDTs with Faceplates
sinking-and-sourcing-digital-output-modules
PLC Digital Signals Wiring Techniques
How to Troubleshoot a PLC System
How to Troubleshoot a PLC System?
PLC Program for Automatic Bottle Rejection System
Siemens PLC Organization Blocks used For Troubleshooting
Tia Portal – OB121 Programming Errors Interrupt Organization Block
Delete Siemens CPU Memory
PLC Tutorials - Timers and Counters
Difference between Timer and Counter – PLC Basics
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Retentive ON delay timer using PLC Logic
Retentive ON Delay Timer using PLC
Induction Motor Rotor Frequency
RC snubber circuits
How Snubber Circuit works ?
Pressure Switch Questions
Three Phase Converter Multiple Choice Questions
Difference-between-pneumatic-electric-hydraulic-actuators
Difference between Pneumatic, Electrical & Hydraulic Actuators
Modbus ASCII and RTU Message Frame
Background of Modbus – ASCII and RTU Data Frames
RF Admittance Level Transmitter Working Principle
O Ring Failure
How O-Ring Failure caused NASA’s shuttle to Blast ?
