Reading: PLC Program for Automatic Bottle Rejection System
Inst Tools > Blog > Guest Articles > PLC Program for Automatic Bottle Rejection System
This is the PLC program for the automatic bottle rejection system. Learn the ladder logic with this PLC exercise and solution.
Last updated: November 3, 2023 10:56 am
Guest Articles PLC Tutorials
Automatic Bottle RejectionPLC Problem DiagramPLC Problem SolutionList of Inputs/OutputsPLC Program for Automatic Bottle Rejection SystemPLC Program ExplanationResult
Problem Description
Nowadays Automation in industries is necessary for Accurate and fast Production.
Let’s Take an Example of soda bottle companies, where the belt conveyor is used for transferring the bottles from one station to another station.
But before bottles reach at soda filling station it is necessary to make all bottles are in standing position for further processing
A fallen bottle on the conveyor may create a problem in the next process. so here we discuss a simple PLC Logic that handles the fallen bottle.
PLC Problem Diagram
So for that we use PLC system at filling station, which reject the fallen bottle from the conveyor & clear the path for the next process.
This process is made by using sensors & actuators. We use pneumatic piston cylinder assembly for pushing the fallen bottles from the conveyor.
When conveyor is running, then all bottles transfer form one station to other station for next process. There are two sensors are used, for standing and fallen bottles detection, one pneumatic cylinder for pushing the fallen bottle from the conveyor.
Inputs List
  • Start PB : I0.1
  • Stop PB : I0.0
  • Sensor X1 : I0.2
  • Sensor X2 : I0.3
Outputs List
  • Cycle ON : Q0.0
  • Conveyor : Q0.1
  • Cylinder : Q0.2
PLC Bottle Filling System
In this application, we have used Siemens S7-1200 PLC and TIA Portal Software for programming. We can also design this logic with relay circuit also.
Network 1:
In Network 1, we have taken cycle ON condition for machine. Here we have taken START PB (I0.1) for starting the cycle and STOP PB (I0.1) for cycle STOP.
We have taken parallel output of conveyor (Q.1) with cycle ON (Q0.0) so we can operate conveyor with cycle ON condition.
Network 2:
In Network 2, we have taken sensors X1(I0.2) and X2(I0.3) as inputs. We used NO contact for X2 (I0.3) sensor and NC contact for X1 (I0.2) sensor.
When Bottles are transferring on the conveyor, these sensors sense the position of the bottles whether they are standing or fallen.
Sensor X2(I0.3) sense down position of the Bottle & Sensor X1(I0.2) Sense top position of the bottle.
In PLC, we designed the circuit which follows command that if sensor X2(I0.3) sense the bottle & sensor X1(I0.2) does not sense the bottle then the pneumatic actuator (Q0.2) will come in action & it will reject the bottle from the conveyor.
After this, the perfect bottles will go in the soda filling station & whole cycle will be completed.
Result
PLC Bottle System
Note: The above PLC Logic provided for basic idea about application of PLC in Automatic Bottle Rejection Handling System. The Logic is limited and not complete application.
Author: Bhavesh
  • PLC Sequence Control
  • Alarm Management System
  • Process Control Systems
  • Stepper Motor MCQ
  • Split Range Control Loop
PLC Program – Controls Conveyors ON and OFF Sequence
Example PLC Program
Basics of PLC Programming
Structured Text PLC Example for Motor Interlocking and Control
  • Karthikeya says:
    May 31, 2024 at 5:55 am
    For the input I 0.2=0& I 0.3=1 the output is not showing cylinder ON
PLC Analog Input Sampling Ladder Logic
What is a Dry Contact? – Basics of PLC Wiring
Ladder Logic for Flow Meter Totalizer
Create a Function (FC) for a Valve Logic in Siemens PLC
Automatic Box Filling System using PLC Programming
How to Create New Project in Studio 5000?
Allen Bradley PLC Subroutines
Real-time and historical SCADA Trends
What are Trends in SCADA?
Siemens PLC
#20 PLC Best Practices – Identify Critical Alerts
PLC Program for Trash Compactor
Reset Logic for pump Run Hours
PLC Program to Count Running Hours of any Equipment
PLC Ladder Logic Example
Cybersecurity in PLC
Sequencer Output in PLC
PLC Sequencer Instruction with Example
Single Excited Electric Field Systems Quiz
Process Control & Instrumentation Objective Questions – Set 1
Pressure Transmitter Circuit
PLC Timer Application in Security Camera Recording
Intrinsic semiconductors
Introduction to Semiconductor Electronics – Types, Materials
Alternator Objective Questions and Answers
125+ Alternator Objective Questions and Answers
Problem on Solar Hot Air Collector and Variable Speed Fan
Inductor Principle
Inductor
