Reading: PLC Program for Bank Counter Application
Inst Tools > Blog > PLC Tutorials > PLC Program for Bank Counter Application
Last updated: March 4, 2021 3:48 pm
2 Min Read
A bank having three counters for Deposit /Withdraw cash in which totally 15 people are allowed for a day. When people count reaches 15, display will show Counter Closed and should not allow the 16th person to check-in. Develop a suitable program for this plc programming example.
PLC Program for Bank CounterList of Inputs and OutputsPLC Counter ExampleLadder Logic DescriptionConclusion:
PLC Counter Example for Bank
PLC Counter Example Inputs and Outputs
PLC Counter ExamplePLC Bank Counter Logic
Counter Example in PLC Programming
RUNG000
Latching rung to operate the system through Master Start and Stop PB.
RUNG001
When a person enters Counter 1, Sw 1 is pressed by the bank person to make count .One shot is used to give single pulse input which will be store in O:0/1
RUNG 0002
When a person enters Counter 2, Sw 2 is pressed by the bank person to make count .One shot is used to give single pulse input which will be store in O:0/2.Counter done bit is used to restrict the 16th person to enter.
Rung 0003
When a person enters Counter 3, Sw 3 is pressed by the bank person to make count .One shot is used to give single pulse input which will be store in O:0/3
Rung 0004
Collected outputs from the above rungs are accumulate in Counter block. Comparator block is used to limit the count by 15.
Rung 0005
Counter (C5:0) done bit is used to refresh the Process from beginning
Program runs continuously until STOP PB is pressed.
Conclusion:
The above explained Bank counter  using PLC is for example only. It may vary from real time. We can use this example program to understand the working of Counters function in AB PLC.
Author : Hema Sundaresan
PLC Timers Program
DeltaV System Download
PLC Quiz Questions
Mixing Process PLC
PLC System Documents
Test and Process Modes in Siemens PLC
What is Recipe Management in SCADA?
Advanced PLC Conveyor Control: Forward and Reverse Rotation
Electrical Switches Principle & Types
FC Function in Siemens PLC
Micro Memory Card (MMC) in Siemens PLC
How to Use ModScan Software for Testing Modbus Communication?
Jump Instruction in Siemens Tia Portal
Allen Bradley PLC to PLC Communication in Studio 5000
How to Communicate with Excel from Intouch SCADA?
S7-1200 Hardware Configuration – Siemens PLC Tutorials
Start the Counting from a Preset Value in PLC
Concept of Interlocking in PLC
DC Circuit
Main differences between Sinking and Sourcing Circuits
Case Statement in SCL Language
Studio 5000 Logix Emulate Controller
How to Create New Project in Studio 5000?
PLC Program for 2 Push buttons to Control 1 Output
plc-analog-signals-wiring-techniques
PLC Analog Signals Wiring Techniques
Omron CX programmer shift register
The Concept of Shift Register in Omron PLC with Example
Selection of Industrial Temperature Calibrator
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 2
Safety Instrumented Systems Tutorials
High Reliability of Safety Instrumented Systems
Difference between Globe Valve and Gate Valve
Difference between Globe Valve and Gate Valve ?
Magnetic Wind Instruments Questions & Answers
Distributed IO for Siemens PLC
How to Configure Distributed IO in a PLC Project?
What is a Time Delay Relay
What is a Time Delay Relay? Principle, Advantages, Disadvantages
Portable Gas Detectors Calibration Procedure
