Reading: PLC Ladder Logic for Lube Oil Pump Motor
Inst Tools > Blog > PLC Tutorials > PLC Ladder Logic for Lube Oil Pump Motor
Last updated: March 4, 2021 3:23 pm
2 Comments
2 Min Read
Design a ladder logic for providing lubricant for the gear box before the lathe spindle starts to run which aims to ensure that the lube oil pump motor starts first and the main motor starts subsequently ?
  • I0.0– START pushbutton to Start Oil Pump Motor
  • I0.1– START pushbutton to Stop Main Motor
  • I0.2– STOP pushbutton to Stop Oil Pump Motor
  • I0.3– STOP pushbutton to Stop Main Motor
  • Q0.0– Oil Pump Motor
  • Q0.1– Main Motor
This program is a typical application of the conditional control circuit. Q0.0 is ON when Oil Pump START button is pressed. Therefore, the oil pump will start to provide lubricant for the gear box of main motor (Q0.1).
Under the precondition of the operating state of the Oil pump, the main motor (Q0.1) will be ON when the Main motor START button is pressed. During the operation of main motor (Q0.1), oil pump (Q0.0) needs to provide lubricant continuously.
The oil pump will be stopped when Oil pump STOP button I0.2 is activated, and the main motor will be stopped when Main motor STOP button I0.3 is activated.
NOTE :
In real time applications, we may use Time Delays before starting main motor. After starting the Lube Oil Pump, there will be certain time delay ( say 30 sec, 2 min, 5 min) provided to make sure the lube oil pressure is sufficient before running main motor. In some cases time delays also provided during stopping the motors, based on specific applications.
PLC Program Motor Starter
OFF Delay Timer using PLC
PLC, MCC, LCP & Pumps
SCADA Hardware and Software
Purpose of Marshalling Panel
Machine Tool and Coolant Control: PLC Ladder Logic Design
Sequential Operation of Output Bits using Two Push buttons
Down Counter PLC Program
How to Detect Speed of Conveyor in PLC?
Automatic Highway Lights Program using RTC in Omron PLC
Motor Stop Interlock for Changing the Direction PLC Program
2 Comments
  • Md.Salim says:
    November 9, 2019 at 9:09 pm
    Very nice…..
    • Tafere says:
      March 17, 2022 at 11:27 am
      please give good notes about PLC ladder logic
Types of Noise in Electronics
Unknown Do’s Need to Know as a PLC Programmer
Example of Automated Guided Vehicle with PLC
How to Download EcoStruxure Machine Expert? Schneider PLC Software
Design a Water Pump PLC Program using CX-Programmer
What is Trace Function in Tia Portal?
Basic Concepts of the Safety Relay
Industrial Control Systems Security
HMI
How to use PLC With SQL Database
How to use PLC with SQL Database? – Basics & Tutorials
PLC Sequential Operation Example Program
PLC ON DELAY TIMER FUNCTION
#6 PLC Best Practices – Validate Timers and Counters
How to Start Writing SCL in Siemens PLC
Rules for Writing SCL Language in Tia Portal
Intrinsic Safety Barriers
Bi-metal Temperature Gauge
Bi-metal Temperature Sensors
Transmitter Calibration Range of a Vessel Level
Analog Electronics Objective Questions – Set 4
Advantages and Applications of zigzag transformer
Safety PLC Programming steps
Safety Door Interlock PLC Program
Instrumentation of Ion Spectroscopy
S7 1200 PLC Program
Remote Capillary Level Transmitter Mounted below the Zero Level
How to Calculate mmWC Range of Level Transmitter with Examples?
