Reading: PLC based Automatic Packaging System
Inst Tools > Blog > PLC Tutorials > PLC based Automatic Packaging System
Last updated: March 4, 2021 2:16 pm
2 Min Read
Develop a PLC-based ladder logic program for automatic packaging system according to the logic given below,
PLC Packaging SystemPLC Packaging ProgrammingProgram Description:Conclusion:
  1. Start and stop PB is used to start and stop the whole process
  2. Photosensor is used to detect product.
  3. Once the count reaching 10, the robot arm takes responsible for packing.
  4. Packing complete sensor turns on to restart the process
  5. Stop PB is pressed any time to stop all processes.
PLC Packaging
Rung 0000:
Start/Stop Pushbutton (PB) latched with memory B3:0/0.
Rung 0001:
B3:0/0 enabled to turn on Conveyer motor (O: 0/0).
Rung 0002:
Photo-sensor (I:0/1) is connected to one shot to give one pulse when a product crossing photo-sensor.
The counter is used to count the number of the product. Robotic arm for packing (O:0/1) is connected in the normally closed contact to give interlocking with conveyor motor.
Rung 0003:
Counter done bit turns robotic arm for packing (O: 0/1) to turn ON and conveyor motor to stop.
Rung 0004:
Packing complete sensor (I:0/3) or manual counter reset (I:0/4) is used to reset the counter which will turn on conveyor motor to start the process again.
Conveyor Motor (O:0/0) is connected in the normally closed contact to give interlocking with a Robotic arm for packing output.
Conclusion:
We can use this example to understand the ladder logic in AB Programmable Logic Controllers.
Author: Hema Sundaresan
  • PLC based Tank Level Control
  • Drink Dispenser System in PLC
  • Batch Process using PLC Logic
  • Automated Guided Vehicle with PLC
  • Security of SCADA Systems
Identify the Problem in the PLC Program
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Importance of Grounding Electronic Equipment
PLC Programming Example for Motor Forward and Reverse Control
PLC SCL Program for Marking Machine
  • areef says:
    October 27, 2024 at 5:09 pm
    Hi there,
    A newbie engineer student here, can I know what type of programming platform you use for your ladder programming? I just noticed they didn’t look like mine (cx- programmer). Hope you can answer my question so I can understand properly your ladder diagram.
    That’s all, thanks 😁.
HMI Handbook
LIFO Instruction in PLC
SCADA Multiple Choice Questions
Factory I/O PLC Automation Training Course (Free)
FactoryTalk Studio and SQL Server for Data Logging
How Does Redundant Power Supply Work?
PLC Program for Water Level Control Logic
PLC Program for Conditional Control Logic
PLC to PLC Communication using S7 Connection
PLC to PLC Communication using S7 Connection PUT & GET Instructions
scada hmi
Functions of SCADA
Online PLC Ladder Logic
Mis-conceptions of PLC Ladder Logic
Draw a ladder logic to switch ON-OFF a bulb using a toggle switch
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
Add an alarm display to the graphics.
How to Configure an Alarm in InTouch SCADA?
Structured Text PLC Example for Motor Interlocking and Control
Non‐contact RADAR Level Transmitter Pulse
Non Contact RADAR Level Transmitter Principle, Limitations, Design, Installation and Calibration
Master-Slave Flip-Flops Objective Questions
PLC programming for clothes washing machine automation
LS Electric PLC Program Example: Clothes Washing System
Proximity Switch Working Animation
Read Only Memory (ROM) Objective Questions – Part 2
Hardware Description Language Objective Questions
Valve Standards
List of Valve Standards
Start Stop of one Motor from same Push button PLC program
