Reading: How to Password Protect HMI in Siemens TIA Portal?
Inst Tools > Blog > PLC Tutorials > How to Password Protect HMI in Siemens TIA Portal?
Last updated: March 4, 2021 12:30 pm
3 Comments
3 Min Read
How to Protect HMI From Unauthorized Access in Siemens TIA Portal
In the last article, I cover the creation of the HMI screen. Here in this article let’s learn how to password protect HMI data from unauthorized access using Siemens TIA portal.
We all know that HMI contains a lot of information and we have to decide who is going to have which access, we have to enable password feature.
Download: TIA Portal
Let’s have a look into steps as shown below.
Step 1:
Enter in the TIA PORTAL environment.
Select HMI screen size as explained in the article on how to create HMI screen.
Step 2:
As shown in the below window double click on “user administration”.
How to protect STEP 7 (TIA Portal) projects
Step 3:
Clicking on user administration will open the following window. Here you have two options,
  • Users
  • User groups
In the user, you can add the name of the user, automatic log-off time.
In the user group, you can add access to the user.
Password protection Siemens HMI
Step 4:
As shown in the below window by tapping “password” you can set a password.
In the red box you have to checkmark the “automatic on/off” and next set the time as the user leaves the display, it will automatically logoff in the specified time.
How to set password in Siemens HMI
Step 5:
In the user group window, you can make a selection of access.
Here you can see I have selected the “administration group” it has access to all the things which have a tick mark on it. You can change it by removing the tick mark on it.
How to set password in TIA portal
Step 6:
In the second option name, “user” has only access to operate as you can see in the below window.
Tia Portal project HMI user password
Step 7:
Go back to portal view and open “runtime setting”.
Runtime Settings in TIA portal
Step 8:
In runtime, setting choose “user administration” where you can do settings like password validity, password complexity, login attempt, etc. this is a very handy tool to have in your visualization environment.
User Administrator in Siemens Tia Portal
Also Read: How to Crack Step7 PLC Password?
Author: Suhel Patel
  • Ladder Logic Examples
  • How to use Siemens Simulator?
  • Siemens Drum block Sequencer
  • Industrial Automation Protocols
  • S7 1200 PLC configuration
Distributed IO Sharing Between PLC Systems – Technical Insights
How to Wire a Field instrument to Control Room with Example
How to Filter Digital and Analog Inputs in a PLC?
Concept of Interlocking in PLC
3 Comments
  • Krishnaiah says:
    November 16, 2020 at 8:17 am
    Dear Sir,
    This is to bring to your notice that we have entered wrong password three times in HMI login screen and now our production cycle is held up. Vendor is unable to support us.So,Please guide us how to reset or unlock a password in Siemens TP 1200 comfort HMI.
    Please do the needful sir.
    Regards
    Krishnaiah Ch
    • Benjamin says:
      December 1, 2021 at 5:59 pm
      If you have a User View Control in on of your Screens and a User Login with higher rights then you can move the User back to its original Group. Or if you do not have this possibility then you have to overwrite the User Administration (pwx File or complete Project with Overwrite User Administrtaion) to fix it.
  • Marcelo says:
    August 25, 2021 at 12:15 am
    Is possible to see the created password?
208kSubscribersSubscribe
Use of Regions in SCL Language
Normally-open and Normally-closed Switch Contacts
Ferrules and Cross Ferruling
Create a User-Defined Function Block in Codesys
Increment & Decrement Instructions in CX-Programmer (OMRON)
How to Select a SCADA for New Project
How to Select a SCADA for New PLC Project?
Things to Take Care of When Designing SCADA System
Introduction to SCADA
Masked Move Instructions
How to use Masked Move Instruction in PLC
DDE Protocol
What is the DDE Protocol?
Free WinCC SCADA Training Course
Free SCADA Training Course
How to Choose HMI
How to Choose a Suitable HMI for Your Application?
Speed Control of Pneumatic Cylinder (Explanation with PLC)
Production Planning Software
Supplied Screen Vibrators Perennial Problems
Calibration of Temperature Sensor with Indicator
DTS sensors
Distributed Temperature Sensors (DTS) in Power Lines
Network Switch
steam heat exchanger
Practical Process Control System Questions & Answers – 9
Resistor Y and Delta Network Calculation
Y and Delta Resistor Network Calculations
Liquid Level Control using Flow Loop
