Reading: Oscillating Piston Flow Meters Working Principle
Inst Tools > Blog > Animation > Oscillating Piston Flow Meters Working Principle
Oscillating piston flow meters use a precision machined chamber containing a cylindrical piston that oscillates as liquid flows.
Last updated: October 31, 2023 4:08 pm
Animation Flow Measurement
2 Min Read
Oscillating piston flow meters use a precision-machined chamber containing a cylindrical piston that oscillates as liquid flows.
Oscillating Piston Flow MetersAdvantages of Oscillating Piston MetersDisadvantages of Oscillating Piston Meters
The piston’s central shaft is constrained to run in a circular groove in the chamber, resulting in an off-center rotating motion as the liquid sequentially enters and exits compartments machined into the underside of the piston.
Oscillating Piston Flow Meters Animation
Since the volume of the compartments are known, the amount of liquid metered per revolution can be calculated accurately.
Liquid enters a precision-machined chamber containing an oscillating (rotating) piston. The position of the piston divides the chamber into compartments containing an exact volume. Liquid pressure drives the piston to oscillate and rotate on its center hub.
The movements of the hub are sensed through the flow meter wall by a follower magnet. Each revolution of the piston hub is equivalent to a fixed volume of fluid, which is indicated as flow by an indicator/totalizer.
Close clearances between the piston and the chamber ensure minimum liquid slip for highly accurate and repeatable flow measurement of each volume cycle.
  • High accuracy and repeatability.
  • Only one moving part to cause wear.
  • Can be made of materials to ensure sanitary needs of food and beverage processing.
  • Can only be used with relatively clean liquids.
  • Variable Area Flowmeters
  • Flow switch Principle
  • Types of Flow Measurement
  • Disadvantages of Flow Meter
  • Paddle Wheel Flow Meters
What is a Positive Displacement Flow Meter?
How a Transistor Switch Works
Pitot Tube Working Principle
Sight Glass Level Measurement Principle
Optical Flow Meter Principle
  • jmw says:
    February 5, 2020 at 11:57 pm
    This looks like the Neptune Red Seal chamber.
    In the US these are commonly referred to as oscillating piston. This is not, as some have claimed, to be to avoid confusion with the reciprocating piston meters but because the more common description is, everywhere except the USA< Rotary Piston.
    In the USA the term rotary piston had already been applied to Lewis Nash's Crown meter (a true PD meter with more in common with a gear meter visually).
    The terms rotary and piston could be related to the expectation that the Crown meter would satisfy the need for a universal water meter, one able to handle both direct plumbing (rotary or rotary vane meter market) and indirect plumbing (reciprocating piston meter market) and which it probably did achieve with territorial limits for a while.
Pushbutton switches and Types of Switches
Importance of Flow Meter Turndown Ratio
Comparison of Venturi and Orifice flow meter
Cat and Mouse type Level Indicator
How to Measure Pressure in Inches of Water Column
Spring Loaded Variable Area Flow Meter Working Principle
V Cone Flow Meter Working Principle
V Cone Flow Meter – Principle, Advantages, Disadvantages
Linear to Square Root Extraction
magnetic flow meter parts
What is a Magnetic Flow Meter?
Electrical-Switches-Working-Animation
Electrical Switches Working Animation
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Ultrasonic Level Switch Working Animation
Ultrasonic Level Switch Working Principle
Ultrasonic Sludge Blanket Level Meter Animation
Bernoulli's Principle and Flow Meters
Phase Controlled Half Wave Rectifier RL Load
Power Electronics – Phase Controlled Half Wave Rectifier RL Load
PLC Programming for Pumping and Draining System
Bourdon Tube Gauge Spiral Spring
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
Interview Questions for Instrumentation Engineer Freshers
Direct Acting Solenoid Valve
Top 5 Things for selecting a Solenoid Valve
hall-effect-sensor
Hall Effect Sensor Working Principle Animation
Smart Sensors Objective Questions
Transmitter Calibration Range of a Vessel Level
