Reading: Orifice Plate Turndown ratio
Inst Tools > Blog > Flow Measurement > Orifice Plate Turndown ratio
Why Orifice Plate is having a 3:1 Turndown Ratio in Practice ? Using orifice plate as a flow element, to limit the using in a 3:1 to 4:1 turndown ratio.
Last updated: October 31, 2023 1:40 pm
Flow Measurement
It is a general practice in the differential type flow meter, using a flow orifice plate as a flow element, to limit the use in a 3:1 to 4:1 turndown ratio. Where does this general practice come from?
Why Does Orifice Plate Have a 3:1 Turndown Ratio in Practice?Orifice Plate Turndown RatioExample of Orifice Flow Meter Error Reading Calculation
The limitation of the DP-type flow meter using an orifice doesn’t come from the beta ratio limitation of the flow orifice plate nor any other flow orifice plate dimension.
The limitation comes from the error reading caused by the non-linear relationship between the differential pressure across the flow orifice plate and the calculated flow rate.
In simplified concept, we can calculate the orifice flow rate by:
Qm = C x (Differential Pressure)^0.5
Where,
Qm: Flow rate
C: Meter Constant
Differential Pressure: differential pressure across flow orifice plate
From the above equation, we know that the flow rate is proportional to the square root of the differential pressure. This non-linear relation produces a significant error in the lower flow when the turndown ratio exceeds 3:1.
Basically, the differential pressure transmitter itself can have a turndown ratio up to 100:1 but the square root extraction limits its capability in the upper range only.
See below calculation example below that illustrates the increase in error reading when the turndown ratio is below 3:1.
Orifice Flow Transmitter Turndown ratio
From the above example, we know that the % error reading (after performing the above square root calculation) is increasing along with the flow rate decreasing. The % error reading exceeds 0.5% when the flow rate is lower than 2500 l/m.
Let’s set this flow rate as our minimum flow rate since the flow rate measurement has having high error below this point. If we look further, the 2500 l/m minimum flow and 7500 l/m maximum flow correspond to the 3:1 turndown ratio. This is where the 3:1 turndown ratio is applied in our general practices.
If we insist on having minimum flow let’s say 1000 l/m then we will have a turndown ratio of 7.5:1. This will lead us to get an error reading of 2.8 % which means a very bad measurement accuracy.
Thus some engineer usually simply use a 3:1 turndown ratio as their rule of thumb to decide whether they will use a DP-type flow orifice plate flow meter or not.
If the required turn-down is higher than 3:1, then it will be better if we use another type of flow meter even though it is possible to have such a higher turn-down ratio by installing a parallel DP-type flow orifice plate flow meter with a split range configuration.
I don’t have any reason regarding this except the parallel configuration will give us a high cost of material procurement.
  • Flow Meter Turndown Ratio
  • Restriction orifice versus Orifice
  • Instrument Turndown Ratio
  • Flumes Flow Measurement
  • Rotameter Working Animation
DP type Flow Transmitter Preventive Maintenance and Calibration
Interview Questions on Flow Measurement
Is it Easy to Measure Natural Gas Flow and Volume?
Impulse Line – Purpose & Tapping Point Location
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
What is a Square Root Extractor? – DP Flow Measurement
  • Andy says:
    January 23, 2017 at 4:09 pm
    Nice article, however if the full scale of the transmitter is 200 inH2O and the transmitter accuracy is 0.1% of full scale, is the error in pressure measure not +/- 0.2 inH2O rather than 0.1?
Comparison of Venturi and Orifice flow meter
Difference between Orifice & Restriction Orifice
Wedge Flow Meter Principle
Overview of Positive Displacement Flow Meters
Configure the Instruments in Flow Control Loop
Square-root characteristics of Differential Pressure Flow Meters
Thermal Dispersion Flow Switch Working Principle
Advantages & Disadvantages of Different Flow Meters
Turbine Flow Meter Installation Procedure
Variable Area Flow Meters
Variable Area Flow Meters – Principle, Advantages, Disadvantages
Averaging Pitot Tube Working Principle
Beta ratio ( β )
Important Factors in Flow Measurement
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Coriolis Mass Flow meter as a Multi Variable Transmitter - 1
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
Orifice Taps
Orifice Plate Tapping – Orifice Plate Taps
Orifice plate with vent and drain holes
Basics of Orifice Plates
Magnetic Float Level Switch Principle
Magnetic Float Level Switch Installation Techniques
Harmonic Reduction Objective Questions
Full Wave Diode Rectifier Quiz
Filters in Compressors
PLC Program for Stage Control Curtains and Stage Elevation
PLC Program for Stage Control: Curtains and Stage Elevation
Pressure Gauge Water traps and pigtail siphons
Pressure Gauge Water Traps and Pigtail Siphons
Pictorial Fluid Power Diagram
Hydraulic and Pneumatic P&ID Diagrams and Schematics
Electronic Devices & Circuits Quiz – Set 16
