Reading: Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
Inst Tools > Blog > Flow Measurement > Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
The Restriction Orifice can have a 150# flange rating but the Orifice Flow Meter Flange is not recommended to have a 150# flange.
Last updated: November 2, 2023 11:37 am
Flow Measurement Instrumentation Design
2 Min Read
This question comes to mind? As to Restriction Orifice can have 150# but the Orifice flange (Flow meter) is not recommended to have a 150# rating.
Orifice Flange Rating – 150#The PROOF
We have the answer in one sentence.
It is due to flange integrity !
It means in simple words :- Orifice that are flange tapped have reduced strength
Due to this drilling in between them their pressure-temperature retaining capacity reduces
So to ensure flanges have Strength to withstand Design pressure and temperature a higher rating than 150# i.e 300# is used .
Now There has to be some proof supporting It !!!
The PROOF
The standard we use for Normal flanges below 24” is ASME B16.5
But for Orifice, the flange standard is ASME B16.36
This standard starts with 300# Flange rating.
In restriction Orifice as there are no tapping hence we go with ASME B16.5 flanges which Start with 150# Rating .
As always ! Thanks a lot for Reading !!
PS :- It is observed that for very large line sizes ( Depends few say above 10”, few say above 20”) 150# can be used as these flanges are stronger at higher line sizes but I have not found concrete proof in standards yet.
I would be very grateful if somebody knows the standard that has this documented.
Author: Asad Shaikh
Profile: Linkedin
  • Orifice beta ratio values
  • ANSI Class Relates to PSI?
  • Characteristics of Flow Meter
  • Magnetic Meter Construction
  • K factor Formula of Flow Meter
Instrument Air Compressor Control Philosophy
What is a Positive Displacement Flow Meter?
Oscillating Piston Flow Meters Working Principle
Detail Design Engineering Competency Aspects
Coriolis Flowmeter Advantages and Limitations
How to Select a Inductive Proximity Sensor
  • Albert Hattingh says:
    December 16, 2023 at 3:12 pm
    which would be the best instrument to measure flow in a 4″ gas line? unfortunately the gas contains condensate.
Temperature Gauges and Elements : Detailed Specifications
Orifice Plate Questions and Answers
Basics of Flow Measurement
Instrumentation Earthing
Types of Flow Meters
Facts About Orifice Flow Meters
What is Contact bounce ?
Basics of Thermistors, Thermocouples and RTD's
Basics of Thermistors, Thermocouples and RTD’s
Field Instruments Scaling and Unit Conversions
Configure the Instruments in Flow Control Loop
Differential Pressure Flow Meters
Short Notes on Differential Pressure Flow Meters
Control System Vendor Internal Test Procedures
Vendor View of Supplying Industrial Process Control & Safety Systems
plc-analog-signals-wiring-techniques
PLC Analog Signals Wiring Techniques
Instrumentation Project Documents
List of Instrumentation Project Engineering Documents
Relay Permissive and interlock circuits
FMCW Radar level transmitter Working Principle
FMCW Radar Level Transmitter Working Principle
Tube Fittings - 4
Tube and tube fittings
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
Pneumatic Load Cell Principle
Typical process control loop
How Process Control Loop Works
HMI screen for operator
#8 PLC Best Practices – Validate HMI Input Variables at PLC Level
Measurement and Instrumentation Objective Questions – Part 2
