Reading: Why is Orifice Beta in between 0.3 to 0.7?
Inst Tools > Blog > Flow Measurement > Why is Orifice Beta in between 0.3 to 0.7?
Why we must keep the Orifice Beta ratio between 0.3 to 0.7 values during orifice calculation, orifice design, and selection?
Last updated: November 2, 2023 11:47 am
Flow Measurement Instrumentation Design
From Where do we get these Numbers and What significance do they have that we must keep the Orifice Beta ratio in orifice calculation between 0.3 and 0.7 Values?
Orifice Beta RatioWhat if we take a BETA of 1?What if we take a BETA of 0.9?What if we take a BETA of 0.1?Process HydraulicsMore Probability of Cavitation and FlashingCoefficient of Discharge (Uncertainty)Why only between 0.3 to 0.7
Orifice Beta Ratio
Let us start with What is BETA? Then let’s get rebellious and take “Extreme cases”!!
BETA =  I.D of Orifice (BORE of Orifice) / O.D of Orifice (I.D of Pipe)
Orifice Beta
For Understanding purpose. Let’s get rebellious and take “Extreme cases”
This is possible if I.D of orifice = O.D of Orifice
But that means There is no restriction to flow so no Pressure Drop.
And No pressure drop hence Flow measurement is not possible
This is possible if the I.D of the orifice is approximately near the O.D of the Orifice
But that means There is very little restriction to flow so very little Pressure Drop.
As low-pressure drop will be difficult to measure, so we don’t go beyond 0.7
Also “UNCERTAINTY INCREASES“, this concept is explained below.
Very High Orifice Beta Ratio
This is possible if the I.D of the orifice is very small as compared to the O.D of the Orifice
But that means there is a very high restriction to flow so very High-Pressure Drop.
Very Low Orifice Beta Ratio
This is Good, Right? High-pressure drop means it will be easy to measure.
This is not the only consideration we have !!
It affects a variety of things (Here are a few reasons listed below)
Process Hydraulics
This Affects Process Hydraulic calculation and also leads to Inefficiency in the process as a whole.
As the PUMP will have to PUMP MORE !! As a result Process people in their Datasheet specify maximum allowable Pressure loss in Orifice.
What is the use of purposefully creating more restrictions and then trying to compensate it with more pumping power?
The more we drop the pressure the more the chances of liquid reaching “Vapor Pressure”
And thus more is the chances for “Cavitation and Flashing”
NEXT important consideration
The estimated uncertainty of the empirical coefficient of discharge for concentric, square-edged, flange-tapped orifice meters that are in compliance with this standard (API 14.3.1) is a function of the Reynolds number and the diameter ratio (β)
i.e:- Cd (Uncertainty) is a function of Reynolds Number & Diameter ratio
( Reference API Manual of Petroleum Measurement Standards Chapter 14.3.1 PAGE NO 31)
At very high Reynolds numbers (approx. greater than 1,00000) the uncertainty is only a function of the diameter ratio (BETA) (β)
So Here’s Where Beta Ratio again comes into the picture
Below is a graph from API Standards Chapter 14.3.1 that has Percent Uncertainty Vs Beta Ratio (See Comments in Red)
So from this graph, we can deduce it is better to come to a nearby moderate value of BETA approx.=0.5 for better accuracy !!
Lastly one unanswered question?
There is no hard and fast rule it is just due to the above reasons we try to stay in the moderate range, this limit is established by the “Empirical” Method (That is by experimental means, we have come to this value).
Some standards say we should be between 0.2 to 0.6
Nonetheless, stay Safe and select a moderate value
Thanks for Reading !!
PS: This is as per best of my current understanding !!
Author: Asad Shaikh
Profile: Linkedin
  • When to use Diaphragm Seal?
  • Different Types of Orifice Taps
  • Selection of Flow Instruments
  • Valve Relation between Cv and Kv
  • Safety Instrumented System Failure
Interview Questions on Flow Measurement
Facts on Thermowell Insulation Thickness
Flow Instruments – Selection, Principle & Application
Spring Loaded Variable Area Flow Meter Working Principle
Measure Flow rate using Level Sensors
  • K Sreenivasan says:
    August 14, 2019 at 5:53 am
    Very nicely explained, without complicating with equations
Ultrasonic Flow Meters Animation
Pneumatic Signal Piping and Fittings
What is Marshalling Cabinet?
Instrument Panel Cooling Efficiency Enhancement
Difference between Fixed Area & Variable Area FlowMeters
Why 4-20 mA Standard is so popular ?
15 Loop Diagram Questions
Troubleshooting Ultrasonic Flow Meter Common Problems
Thermowell Problems
Thermowell Problems
Level Gauges
Level Gauge Design
flow-meter-accuracy-calculation
Impact of Flow Meter Accuracy
Location of Measurement Displays
Instrument Control Package (ICP)
Package Control and Safety Systems Implementation Methods
Major issues for Sensors Selection
Averaging Pitot Tubes
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
Types of Flow Meters
Instrumentation Inspection and Quality Control Questions
Choppers MCQ
Radar LT Loop Diagram
Questions on Radar LT Loop Diagram
Cable Tray Routing
Cable Routing
Split-Range, Auto-Selector Ratio, And Cascade Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
Solving Critical Control Valve Hunting
Solving Control Valve Hunting: Instrument Troubleshooting
Difference between Globe Valve and Gate Valve
Difference between Globe Valve and Gate Valve ?
