Reading: NH3 Storage Tanks Ammonia Gas Venting Issue – Root Cause Analysis
Inst Tools > Blog > Root Cause Analysis (RCA) > NH3 Storage Tanks Ammonia Gas Venting Issue – Root Cause Analysis
Root Cause Analysis (RCA): NH3 Storage tanks 12 T/d ammonia gas venting issue and financially cripples a fertilizer plant.
Last updated: September 28, 2022 3:19 pm
S Raghava Chari
Root Cause Analysis (RCA): NH3 Storage tanks 12 T/d ammonia gas venting issue and financially cripples a fertilizer plant besides attracting pollution authorities’ factory closure threat.
NH3 Storage Tanks Ammonia Gas Venting ProblemRCA Queries & AnswersFinal solutionPreparations & Package Commissioning
Article Type:Root Cause Analysis (RCA)
Category:Mechanical
Equipment Type:Miscellaneous Rotating Machine Problems
Author:S. Raghava Chari
Tanks’ pressure controller constantly vented ≈ 12 t/d of NH3, to hold the tank top vapor space pressure at 300-mm WC due to poor availability of NH3 refrigeration compressors.
RCA queries and answers follow:
Q- Explain liquid NH3 storage
A-Storing liquid ammonia at -28o C at atmospheric pressure in cylindrical tanks is the most economical bulk storage method. Around 500 Kg/H NH3 evaporates from the state-of-the-art insulated 20-m tall 5000 T storage tank.
A refrigeration system draws, compresses, liquefies, and puts the liquid NH3 into the tank. The provided refrigeration system compressors’ availabilities were < 20%.
Hence, the tank pressure controller vents the gas to hold the tank pressure below the permitted 300 mm WC; hence, the plant suffered 12 T/day ammonia losses.
The author found the compressors so poorly built that improving was impossible. He recalled an ad on a screw-compressor package refrigeration system. Users’ feedback was exemplary. He ordered one package.
Final solution
Plant crew bolted the rush ordered and 4‑months hence received package skid less motor on the pre-readied foundation,
Reasons for less motor order were:
  1. A surplus 450 KW, 3000 RPM 3.3 KV motor was available in the warehouse
  2. US standard 60 Hz motors run too hot with India 50 Hz power supply
  3. Insisting on a 50-Hz motor would delay the delivery by 3 months
  4. In addition, even 50 HZ labeled US motors often run too hot in India
  1. The plant crew readied the foundation based on the vendors package footprint drawing and loads detail.
  2. Fortunately, 2-spare breakers were available in the 3.3 KV load center. The electrical crew laid the breaker to foundation cable and readied the motor protection system
Mech crew bolted the package on the foundation within 6-hours of receipt. In addition, they bolted the 450 HP motor, aligned it, and coupled it to the package screw compressor.
The electrical crew dressed and connected the already laid cable to the motor.
The instrument crew connected the air supply to the package pressure controller, its output to the throughput control slide valve, and tuned the controller.
The package hummed within 20 hours of arrival. For the first time in ten years fully closed tank vent valve cheered everyone! The ten yearlong ammonia vapor venting ceased forever! The package was indeed a ‘fit and forget system.
Author: S. Raghava Chari
  • Turbo-Compressor Problem
  • Compressor Anti-Surge Control
  • Process Air Compressor Overhauls
  • NH3 Plant Turbo-compressor Problem
  • Failing Plant Air Compressor Drives
Urea Reactor Top Bolted Plug developed Leaks
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
Antifriction Bearings Caused Machine Changeovers Posed Outages
Seal Pressure Instruments Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Replace Failed Motors Quickly and Easily
An Indian Plants all turbines’ low Vacuum & Saudi Plant turbo-compressor only
Erratic Radar Level Gauges Delays a Refinery Commissioning
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Many Bucket Elevator Wrecks rob crew morale
Thermowell Shank to Flange Repeat Weld Leaks
Seawater Pipeline Spools from day-1 leaks threaten Plant Shutdown
Rotary Granulator Drive Root Cause Analysis (RCA)
Less than 40% available Plant Air Compressors made available 100%
Less than 40% available Plant Air Compressors made available 100% for Operations
repairs of welding cast refractory lined box over the hot spots
Too often done riskily repaired Roof Hot Spots eliminated forever
Finned Heater Leaks Sealed
Finned Tube Steam Leaks – Root Cause Analysis
Card Failures in Automation Panels
Automation Panel Electronic Cards Failure investigation
Jackshaft Belt Drive
Poorly Engineered, built & often Failing Plant Air Compressor Drives
Butterfly Valve Failure caused Fire
Butterfly Valve Failure Caused Serious vicinity Heavy Fire
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
CO2 Absorber Graphics in DCS
CO2 Absorber Corroded Wall Thickness & Weld Building
Temperature Gauges and Elements Specifications
Temperature Gauges and Elements : Detailed Specifications
Difference Between LAN and WAN Networks
IPSec
What is IPSec? – Internet Protocol Security
PN Junction Quiz
L2F insertion-style flowmeter
Optical Flow Meter Principle
What is a Rotary Actuator
Difference Between Linear Actuator and Rotary Actuator
Instrumentation Engineering Materials Test
Instrumentation Materials Test
Thyristor Gating Circuits Objective Questions
