Reading: What are Multiphase Flow Meters? – Working Principle, Advantages
Inst Tools > Blog > Flow Measurement > What are Multiphase Flow Meters? – Working Principle, Advantages
A Multiphase Flow Meter (MPFM) is a device used to measure the individual oil, water, and gas flow rates in a multiphase flow.
Last updated: November 1, 2023 9:54 am
Flow Measurement
3 Comments
Multiphase Flow Meters (MPFM) are devices used to measure the individual oil, water, and gas flow rates in a multiphase flow.
What are Multiphase Flow Meters?Multiphase Flow Meter PrincipleAdvantages of Multiphase Flow MetersProduction allocation meteringFiscal or Custody transferProduction OptimizationFlow AssuranceApplications of Multiphase Flow Meters
The term MPFM is used to define also the metering of wet gas streams (i.e. multiphase flow where the gas content is very high).
A multiphase flow meter is a device used to measure the individual phase flow rates of constituent phases in a given flow (for example in the oil and gas industry) where oil, water, and gas mixtures are initially co-mingled together during the oil production processes.
Magnetic resonance makes use of a fundamental property of atoms and in effect makes it possible to “count” hydrogen atoms. Since oil, gas, and water all contain hydrogen atoms, multiphase flow can be measured using magnetic resonance.
For this purpose, the fluids are magnetized and subsequently excited by radio frequency pulses. The hydrogen atoms respond to the pulses and send back echoes which are recorded.
The amplitude of the echoes and the rate at which they decay is used to calculate the flow rates. The difference in magnetic resonance properties allows making a distinction between the flow rates of oil, gas, and water.
Multiphase Flow meter Working Principle
Conceptually, a magnetic resonance multiphase flow meter consists of three sequential steps:
  1. Creating a net magnetization by aligning the magnetic moments of hydrogen atoms in an applied, constant magnetic field.
  2. Perturbing the alignment of hydrogen atoms by employing electromagnetic radio frequency (RF) pulses.
  3. Detecting the radio-frequency signal emitted by the hydrogen atoms during their return to equilibrium alignment in the external magnetic field
This measurement principle also forms the basis of magnetic resonance-based flow metering.
Multiphase Flow Meters (MPFM)s are recognized to provide a number of additional benefits to O&G production:
MPFM can be employed to reconcile oil, gas, and water measurements at all entry and exit points of a production network, minimizing potential serious economic consequences in terms of taxes and custody transfer due to incorrect allocation;
when a single processing facility is shared by different producers, MPFMs can be used to meter the production from each license owner;
Multiphase flowmeters are able to deliver real-time, continuous data concerning the production of the different phases; therefore they can be very useful for reservoir management and for optimization of production.
Flow Assurance
The continuous measurement from MPFMs provides further information to detect potential issues in the production system.
Multiphase streams are typical of the O&G fields since the producing wells normally generate a mixture of liquid and gaseous hydrocarbons with a variable quantity of water.
Knowing single rates of gas liquid and water is crucial for the production industry in order to monitor the reservoir, to improve the well performances, and to optimize the production.
The traditional solution is represented by the test separators, large vessels where the different phases are divided and then measured through standard single-phase techniques.
However, MPFM is becoming more and more appealing to the O&G Upstream industry, proving as a valuable alternative to the test separators.
Reference: krohne & Abb
  • Averaging Pitot Tube
  • Flow measurement Basics
  • Impeller Flow Sensor Principle
  • What is the Coriolis flow meter?
  • Ultrasonic Flowmeters
Lobed Impeller Flow Meters Working Principle
Flow Nozzle Principle, Advantages, Disadvantages, Applications
Weirs and Flumes Flow Measurement
Types of Flow Meters MCQ – Instrumentation and Control
How to do Turbine Flow Meter Verification?
3 Comments
  • Manojbabu says:
    December 8, 2016 at 5:58 am
    Possible to get Radio active source type multiphase flow meters of slamburger make, working principle.
  • George Ibraheem Yokhana says:
    November 26, 2018 at 4:03 pm
    Dear
    thanks for the technical clarification about the method of measurement multi phase fluid flow especially for CPF application (central processing faculties ) for oil/gas /water separation in the oil field .
    My question is :Is there another physical method to measure the flow of each fluid or it is only using hydrogen atom or magnetic moments
  • SHYAM MUDBHATKAL says:
    June 21, 2019 at 10:36 am
    We are looking for mass flow meters for measuring the out put of our ASU.
    The product is LIQUID OXYGEN LIQUID NITROGEN AND LIQUID ARGON.
    Please suggest the make and type etc.,
What is a Positive Displacement Flow Meter?
Swirl Flow Meters Working Principle
What Factors Affect the Stability of Flow Meter Readings?
Flow Meter Calibration
Configure the Instruments in Flow Control Loop
Factors Affecting the Performance of Ultrasonic Flow Meters
Why Flow is Directly Proportional to the Square Root of DP?
Electromagnetic Flow Meters Working Principle
Orifice Specifications
Flow meter Turndown Ratio
Importance of Flow Meter Turndown Ratio
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
Bernoulli's Principle and Flow Meters
Oscillating Piston Flow Meters Principle Animation
Coriolis Flow Meter Inaccuracy
Coriolis Flow Meter Uncertainty and Inaccuracy
Vortex flow meter Bluff Body
Types of Vortex Flow Meter Sensors
How a Δp flow meters works
What is Differential Pressure Flow Meter?
Digital Electronics MCQ
Quine McCluskey Logic Functions Objective Questions
How to Test a Transistor using Multimeter
Instrumentation Logic Checks
How to Do Logic Checks During Plant Pre-Commissioning
Moving Iron Vane Meter Movement
Liquid Scintillation Counters Questions & Answers
Electrical Torsion Meter
Electrical Torsion Meter Principle
Field Instruments enclosures
Pressure Transmitter Heated Enclosures
Guided-wave Radar Asset Management Parameters
