Reading: What is Masking in PLC?
Inst Tools > Blog > PLC Tutorials > What is Masking in PLC?
Masking means to filter the data which you don’t want to use while execution of the PLC programming.
Last updated: March 4, 2021 11:12 am
This article is about the function of the masking in the PLC. Here, I will use Siemens TIA PORTAL.
Masking helps us to cover something or mask which you don’t want to see. In the PLC terms Masking means to filter the data which you don’t want to use while execution of the PLC programming.
You may have noticed when you make a purchase, At the time of payment when you enter your ATM card number, it won’t allow you to use any alphabet that what you can call is masking.
Masking in PLC
Let’s understand the function of masking with an example. Do follow the below example and also play around with the different values to understand it.
For example, let say I have a temperature transmitter. As this is an analog signal data type, so we need a word or doubleword data type.
I want that if PLC receives a signal from a temperature transmitter, I need some data to masked off. The bit which I want to mask off is “00FF” which in binary represented as “0000 0000 1111 1111”.
Now we will implement the above example. Open TIA PORTAL.
In the logic operation, add AND instruction.
I already have covered an article on logic instruction. Please find it from somewhere down and read it.
Word Logic Operations
In this below window I added AND instruction to mask off some data coming from the temperature transmitter.
In “IN1”, IW0 is an input signal which is coming from the temperature transmitter. In “IN2”, I have used “00FF” which is a value that I want to mask off. The output of ANDing will be written to a memory word MW2.
You can use other logic instructions too and also you can play with a value to know the function of the masking.
If I run the logic, you can see the result in the below window.
In IN1, I have used “FFFF” which in binary represented by 1111 1111 1111 1111.
In IN2, I have used “00FF” which in binary represented by 0000 0000 1111 1111.
As I have used ANDing operation, we know that when both inputs are “1” then the only output will be energized.
The ANDing result in the output you can get is “0000 0000 1111 1111”. Which you can see in the simulation window.
Masking in PLC
This is how masking can be done. If you still have any question or any doubt then put your question in the comment section.
Author: Suhel Patel
  • Midline Instruction in PLC
  • Create a Project in LabVIEW
  • Turbine Temperature Alarms
  • Communication Processor Module
  • Delete the Siemens CPU Memory
Chemical Mixing Process using PLC
Identify the Problem in the PLC Program
#8 PLC Best Practices – Validate HMI Input Variables at PLC Level
What is Rewire Tool in Simatic Manager?
What is PID Controller?
Example of Automated Guided Vehicle with PLC
How to do Simulation in Schneider PLC?
PLC Programming Example on Timers Function Block
Omron PLC Project: Fish Farm Automation Tutorial
PLC Programming for Multi-Color Sorting Conveyor System
PLC Multiple Choice Questions
How to use PLC with SQL Database? – Basics & Tutorials
PLC Program for Conveyor System
PLC Conveyor Ladder Logic Program
PLC Commissioning and Testing
PLC Commissioning and Testing Procedure (Programmable Logic Controller)
How to Activate the Schneider PLC Software License
How to Download EcoStruxure Machine Expert? Schneider PLC Software
Check Block Consistency Tools
Check Block Consistency Tools in Simatic Manager
Siemens Industrial Laptop (Simatic Field PG)
Connect to the Siemens S7 PLC
Sharing data between two PLC systems
Distributed IO Sharing Between PLC Systems – Technical Insights
Difference Between Microcontroller and PLC
Water Treatment Plant SCADA
Typical HMI Screen Design for Water Treatment Plant
Communication between Intouch Scada and Allen Bradley PLC
Communication between InTouch Scada and Allen Bradley PLC
Thermocouple Questions
Thermocouple Terminal block Questions
Technologies for Oxygen Gas Measurement
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
Automation in Logistics Industry
Instrumentation Basics - Range Conversion Formula and Examples
Instrumentation Basics – Range Conversion Formula and Examples
Electrical Machines MCQ Series 6
