Suppose a technician wishes to use a loop calibrator to simulate a 4-20 mA signal to a controller, and decides to connect the loop calibrator to the circuit like this:
Loop Calibrator to Simulate a 4-20 mA Signal
Explain why this is an improper use of the loop calibrator, and what will happen if the technician tries to simulate a 9 mA signal this way. Finally, identify the proper way to use the loop calibrator to simulate a transmitter signal.
Share your answers with us through comments.
- How to use Loop Calibrator
- 4–20 mA Control Loops
- As-Found and As-Left
- Loop Powered Instruments
- Loop Checks Transmitters
Credits: Tony R. Kuphaldt
The calibrator is not even in closed loop and it is connected as a parallel dc source which will add more mili amps to the instrument additional to the controller mamps supply. Thus the operation of the instrument will be not as expected.
Once we have simulate the mA values to the DCS with probes directly to the 24v dc cores without the connection in the tx.
