Reading: Locked Open (LO) and Locked Closed (LC) Valves
Inst Tools > Blog > Control Valves > Locked Open (LO) and Locked Closed (LC) Valves
Locked Open (LO) and Locked Closed (LC) Valves ensure that critical manual valves remain in their intended position during normal operation.
Last updated: October 17, 2023 3:18 pm
R Jagan Mohan Rao
Control Valves
In the plant documentation, the abbreviation LC stands for Locked Open and LC for Locked Closed. The valve type may be Ball, Butterfly, Gate, Globe, or any other.
Mechanical Locking of ValvesWhy Use Locked Open or Locked Closed?Locked Open (LO) ValveLocked Closed (LC) Valve
Locked valves in the industrial environments are those valves their requirement is identified during the design phase, as being essential to the safety and integrity of the facility.
Valves are often specified with an arrangement to add a locking device as part of the scope of supply of a vendor.
The locking device may be either a cleat located on the body of the valve, through which a chain or a D-lock can be placed, or a plate with a drilled hole on a valve.
This kind of locking arrangement is identified on Process Flow Drawing (PFD) or Process and Instrumentation Drawings (P&ID) and the other related documentation as LC (locked closed) or LO (locked open).
The method of Locked open and locked closed prevents the accidental operation of crucial valves in pressure safety relief lines or liquid drain lines.
To change the function of a valve from open to close or from close to open, it will only be done by authorized operators designated by the name “key personnel.”
To this day this is the preferable and favorite protective method of valves to be locked open or locked closed.
Lock Open (LO) And Lock Close (LC) Valves
The need for a more sophisticated method of locking became more important to prevent the possibility of sabotage also had to be considered.
These concerns led to the development of the mechanical interlocking system, which comprises a hard metal piece of equipment that can be fitted to all manual and actuated valves. Its operation to be carried out in an individual or sequence with other valves.
An example of a sequence locking procedure is a pig launcher/receiver system in Oil and Gas industry.
One key is used to lock open and the other key is used to lock closed the valve.
The keys used to lock closed the valve or lock open the valve are always retained in a key cabinet that is located in the control room.
Only an authorized “key” personnel will have access to this cabinet.
 The use of Locked open or Locked closed (LO/LC) valves is often related to safety.
This kind of arrangement provides a means to ensure that some critical manual valves remain in their intended position during normal operation.
They are not un-intentionally operated. Working with such a system requires strict procedures to manage the position of the valves and to manage their locks.
It will establish a strong safety culture within the organization.
For example, pressure vessels are mounted with Pressure Safety Valves (PSV) with valves in Locked Open (LO) valves would be on the inlet and the outlet of Pressure Safety Valves (PSV).
The Locked open valves are a kind of isolation valves on the inlet and outlet of a PSV that must remain open during normal operation in order that they can protect the equipment on which they are mounted.
Unintentional or accidental closure of those valves during normal operation could prove catastrophic consequences. Hence it is the requirement to lock them in their open position.
For example, a valve in locked Close (LC) would be on a line to the maintenance closed drains system.
Entry of flammable hydrocarbons in the maintenance closed drains system during normal operation is hazardous. That is the reason the isolation valve on the drain line must be closed during normal operation.
  • The locked status at site shall be maintained in the appropriate register.
  • Some organizations audit on LC, LO status for every four months.
  • Permit to work system procedure need authorization while changing normal state of a locked valve.
Reference: Valve Hand Book by Peter Smith, RW Zappe.
  • Valve Interlock
  • Cavitation Test Setup
  • Solenoid Valves Terminology
  • Terms Used in Control Valves
  • Control Valve Air Lock Relay
Introduction to Types of Valves
Air Cylinder Consumption Calculation for Control Valves
Reversing Control Valve Actuator Fail Safe Mode
Electric Motor Actuator Parts
Free Control Valve Software Download
Butterfly Valves – Concentric, Double-offset, and Triple-offset
Difference Between the Control Valve and Shut-off Valve
How to Choose a Control Valve?
Automated Block Valve (ABV)
What is Complementary Split Range Control (CSRC)?
Self-actuated Temperature Regulator – Principle, Types, Advantages
Basic Requirements of Control Valves Sizing
Level Control Valve with Horizontal Float
Calculate Control Valve Stem Position
Direct Acting Actuators
Effect of Differential Pressure on Control Valve Lift
PRV
cavitation-control valve trim
What is Control Valve Cavitation ?
Control Valves Multiple Choice Questions
Special Control Valves
Types of Pneumatic Valves
Types of Pneumatic Valves : Poppet & Spool
Objective Questions on Valves
Valve Pneumatic Actuator
What is a Pneumatic Actuator ?
custom metal fabrication
Custom Metal Fabrication Techniques for Quality Machined Parts
siemens plc db addressing
FB Block in Siemens PLC Programming
Zener Diode Limiter Working
Zener Diode Limiter
How to Check the Continuity of Protective Conductors
How to Check the Continuity of Protective Conductors?
Load Cell Assembly
Urea Bagging Plant – Process Flow
PLC Program Backup in Siemens Tia Portal
How to Take Program Backup from Physical PLC? – Siemens PLC
Closed Tank Liquid Level Measurement using Pressure Transmitter
Inferential Measurement based on Pressure
Sharing data between two PLC systems
Distributed IO Sharing Between PLC Systems – Technical Insights
