Reading: Lobed Impeller Flow Meters Working Principle
Inst Tools > Blog > Flow Measurement > Lobed Impeller Flow Meters Working Principle
Lobed impeller flow meters consist of two impellers rotating in opposite directions due to the forces exerted by the gas flow being measured.
Last updated: October 31, 2023 3:32 pm
Flow Measurement
3 Min Read
Two rotating impellers, designed with a figure eight cross-section, rotate in opposite directions due to the forces exerted by the gas flow being measured.
Lobed Impeller Flow MetersAdvantages of Lobed Impeller Flow MetersLimitations of Lobed Impeller Flow Meters
The shape of the impellers prevents contact while the gap between them remains constant.
A gear drive external to the measuring chamber synchronizes the impellers. During each rotation, four crescent-shaped volumes are moved through the measuring chamber. The number of rotations is proportional to the flow. The rotation is coupled using an adjustable fine-tooth gear train to the totalizer.
An unmeasured flow, which is a function of the pressure drop, flows through the gaps. The negative error is compensated by an adjustment. The viscosity of flow increases at high pressures and reduces the losses in the gaps which compensates for the higher losses which would otherwise exist due to the higher pressure difference.
The pulsations in the flow discharge can cause the pipe system connected to the meter to vibrate. If resonance should occur, loud noises and sudden pressure drops can result. This condition should not be allowed to occur; if necessary noise or pulsation dampers should be utilized.
Lobed Impeller Flow Meters Graph
The pressure drop results from the mechanical and dynamic resistances in the meter. The dynamic portion increases appreciably with increasing load.
Lobed impeller meters are very susceptible to contamination. Since contamination affects the pressure drop it must be monitored and the meter cleaned when required.
  • Excellent measuring accuracy for gas measurements
  • No inlet and outlet sections required
  • No external power supply
  • Volume totalizer
  • For gases only
  • Moving parts, wear
  • Flow blockage at zero flow through solid impurities
  • Sluggish toward quick changes
  • Also affected by quick changes at high differential pressure, the danger of over speeding
  • Monitoring
  • Piston Flow Meters Working
  • Multi-phase Flow Meter
  • Advantages of Flow Meter
  • Different Flow Meters Types
  • What is an Orifice Flow Meter?
Thermal Dispersion Flow Switch Working Principle
Basics of Venturi Flow Meter
Types of Orifice Plates & Orifice Plate Tappings
All About Variable Area Flow Meters
What is a Magnetic Flow Meter?
Wedge Flow Meter Principle
Coriolis Meter Explained with Animation
Important Factors in Flow Measurement
How to Select a Rotameter? – Parameters and Applications
Mass Flow Meters
How to do Turbine Flow Meter Verification?
Differential Pressure (DP) Flow Meters Range Calculation Methods
W Type Transit Time Flow Meter
Transit Time Flow Meter – Types, Advantages, Disadvantages
Heat Tracing Problems
Flow Switch Working Principle Animation
Working Principle of Flow Switch with Animation
Flow Measurement
Continuous Flow Measurement
Sick Flow meters
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Flow Standards
Flow Standards
Advantages and Disadvantages of Flow Measurement Techniques
Advantages & Disadvantages of Different Flow Meters
Pressure Temperature Compensation Flow Measurement
Demultiplexers Quiz
Digital Electronics Objective Questions – Set 11
Change-of-Quantity Flow Measurement
Advantages of Star and Delta Systems
De-energized Electrical Circuits
De-energized Electrical Circuits, Networks, and Equipment
Calculate Incident Power in Radar Level Measurement
PLC Ladder Logic Questions and Answers
