Reading: What is Instrumentation Control System ?
Inst Tools > Blog > Control Systems > What is Instrumentation Control System ?
Last updated: February 28, 2019 11:16 am
Control Systems
3 Min Read
An instrumentation control system is an electrical, electronic, or programmable electronic system (E/E/PES) which may perform some or all of the following functions:
  • Monitoring, recording and logging of plant status and process parameters;
  • Provision of operator information regarding the plant status and process parameters;
  • Provision of operator controls to affect changes to the plant status;
  • Automatic process control and batch/sequence control during start-up, normal operation, shutdown, and disturbance. i.e. control within normal operating limits;
  • Detection of onset of hazard and automatic hazard termination (i.e. control within safe operating limits), or mitigation;
  • Prevention of automatic or manual control actions which might initiate a hazard.
Instrumentation Control Systems
These functions are normally provided by, alarm, protection (trip, interlocks and emergency shutdown), and process control systems.
These engineered systems are individually and collectively described as control systems, and may be independent, or share elements such as the human interface, plant interface, logic, utilities, environment and management systems.
The human interface may comprise a number of input and output components, such as controls, keyboard, mouse, indicators, annunciators, graphic terminals, mimics, audible alarms, and charts.
The plant interface comprises inputs (sensors), outputs (actuators), and communications (wiring, fibre optic, analogue/digital signals, pneumatics, fieldbus, signal conditioning, barriers, and trip amplifiers).
The logic elements may be distributed, and linked by communications, or marshalled together and may be in the form of relays, discrete controllers or logic (electronic, programmable or pneumatic), distributed control systems (DCS), supervisory control and data acquisition (SCADA), computers (including PCs), or programmable logic controllers (PLC). The logic elements may perform continuous control functions, or batch or change of state (e.g. start-up/shut-down) sequences. It should also be noted that logic functions may be distributed to be undertaken within smart sensors or actuators.
Utilities are the power supplies and physical elements required for the systems, such as electricity and instrument air.
Environment is the physical accommodation and surroundings in which the control systems (including the operator) are required to work, including physical accommodation or routings, environmental conditions (humidity, temperature, flammable atmospheres), and external influences such as electromagnetic radiation and hazards which might affect the operation of the control system during normal or abnormal conditions such as fire, explosion, chemical attack etc.
Modern instrumented control systems are generally electrical, electronic or programmable electronic systems (E/E/PES), but some purely pneumatic systems may still be in operation.
Note :  Contains public sector information licensed under Open Government Licence v3.0.
Articles You May Like :
What is Emergency Shutdown System (ESD) ?
Stop Cyber Attacks on Control Systems ?
Types of Control Systems
4-wire Passive versus Active Transmitters
Practical Process Control System Questions
SCADA & Telemetry Systems
Inductive Coupling Effects
Instrumentation and Control (I&C) Design
Manufacturing Execution System (MES) in Industrial Automation
What is Instrumentation and Control ?
Instrumentation Cyber Security Glossary
Overview of HIPPS System
Switch or Transmitter
Difference between Process shutdown and Emergency Shutdown
PID Controllers : Parallel, Ideal & Series
Instrument Loop Test Requirements and Operation Procedures
Switches, Repeaters, Bridges, Routers, Firewalls
Why 4-20 mA Current Signal is used instead of Voltage Signal?
DCS System Cabinet
Yokogawa DCS System Maintenance Procedures
PLC Motor Logic
What is NEST loading=
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
PID Simulator
PID Simulator Download
GuideLines for Loop Checks
How to Do Loop Checks During Plant Pre-Commissioning
Feedforward Control
Feedforward Vs Feedback Control
Instrument Linearity Error
Instrument Errors – Zero, Span, Linearity
Single Phase Earth Return System
Single Phase Earth Return System Advantages & Disadvantages
Sensors and Transducers Objective Questions
Functional Design Specifications (FDS) for DCS and SIS Projects
Functional Design Specifications for DCS and SIS Projects – FDS Document
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
valve actuator yoke
Disassembly of Sliding-stem Control Valve
Logic for Always ON and Always OFF bit
Always ON and OFF Bit using Ladder Logic and Statement List
What is Profibus
What is Profibus? – A Comprehensive Guide for Beginners
