In this article, we provide you the basic Instrument Calibration Questions on transmitters like pressure, transmitter, level and differential pressure transmitter.
Question 1:
Suppose you wish to calibrate an electronic pressure transmitter to an input range of 0 to 50 inches of water, with an output range of 4 to 20 mA. Complete the following calibration table showing the proper test pressures and the ideal output signal levels at those pressures:
Question 2:
An electronic pressure transmitter has a calibrated range of 0 to 200 inches of mercury, and its output signal range is 4 to 20 mA. Complete the following table of values for this transmitter, assuming perfect calibration (no error):
Question 3:
An electronic level transmitter has a calibrated range of 0 to 2 feet, and its output signal range is 4 to 20 mA. Complete the following table of values for this transmitter, assuming perfect calibration (no error).
Question 4:
A pneumatic differential pressure transmitter has a calibrated range of −100 to +100 inches of water column (” W.C.), and its output signal range is 3 to 15 PSI.
Question 5:
Suppose you wish to calibrate an RTD temperature transmitter to an input range of 50 to 200 degrees F, with an output range of 4 to 20 mA.
Complete the following calibration table showing the proper test temperatures and the ideal output signals at those levels:
Question 6:
A temperature transmitter has a calibrated range of -80 to 150 degrees F and its output signal range is 4 to 20 mA. Complete the following table of values for this transmitter, assuming perfect calibration (no error).
Instrument Calibration Solutions
Join the Disucssion! Share your Answers with us through below comments section.
- Flow Meter Calibration
- Calibration Error sources
- MCQ on Calibration
- Common Calibration Mistakes
- Calibration of Control valve
Credits: Tony R. Kuphaldt
The charge endues due to mechanical stress on the conductors is called?
What kind of wave form is used for the oscilloscope operation?
The flow meter is used for no loss is called………..?
What is the type of level instrument which operates as per differential methods
