Reading: In-Line Flow Switch Working Principle and Animation
Inst Tools > Blog > Animation > In-Line Flow Switch Working Principle and Animation
In-Line Flow Switch, As liquid flow enters the flow switch, it passes through an orifice between the inlet and outlet ports.
Last updated: October 31, 2023 1:02 pm
Animation Flow Measurement How It Works Switches
2 Min Read
The In-Line Flow Switch is comprised of two main assemblies: the housing and the shuttle assembly. As the liquid flow enters the flow switch, it passes through an orifice between the inlet and outlet ports.
In-Line Flow SwitchLiquid Flow Monitoring
In-Line Flow Switch
In Line Flow Switch Working Principle Animation
When the flow reaches the switch’s setpoint, a magnet shuttle overcomes the downward force of a return spring and actuates a hermetically sealed SPDT reed switch element inside the bonnet stem.
As the flow decreases, the spring overcomes the lifting force created by the liquid and deactivates the switch.
Flow switches are commonly used at multiple points in these types of water applications.
The flow switch provides pump protection by detecting a no-flow condition of the water in the process which prevents damage to the pump before the line is pumped dry.
The flow switch is a low-cost and reliable way of protecting a pump.
Flow Switch Principle
  • Animation of Float Level Switch
  • What is an Orifice Meter?
  • Positive Displacement Meters
  • Flow Measurement Guide
  • Weigh Feeder Flow Measure
Microwave Barrier Level Switch Working Principle
Magnetic Flow Meter Corrosion Effects
Basics of Restriction Orifice (RO) – Types, Applications, Standards
TOC Analyzer Working Principle
Is it Easy to Measure Natural Gas Flow and Volume?
Turbine Flow Meter – Principle, Advantages, Disadvantages
  • Soniya says:
    January 18, 2016 at 2:12 am
    Is very good for me. Thanx
Safety Switches for Controlling Conveyor Operations
Basics of Ball Valves
Radar Level Transmitter in Briddle level Measurement
Overview of Proximity Switches
Basics of Flow Measurement
Pressure based Flow Meters
What is a Positive Displacement Flow Meter?
Piston Flow Meters Working Principle with Animation
different flow measurement technologies
Different Flow Measurement Technologies
NO NC Contact Animation
Equivalent Logic Gates using PLC Ladder Diagrams
Vibrating Fork Level Switch Working Animation
Oscillating Piston Flow Meters Principle Animation
limit-switch-works
How Limit Switch Works ?
Magnatic Level Indicators Working Animation
Venturi Flow Meter
Venturi Flow Meter – Working Principle, Advantages, Animation
Switch High level alarm occurs
Basics of Switches & its applications
Air Purge Level Measurement Principle
Air Purge or Air Bubbler Level Measurement
Types of Control Valve Trim
Phase Failure Relay
Why is Phase Failure Relay Required in LV Panels?
Intelligent Motor Control Center
What is an Intelligent Motor Control Center? – IMCC
Stability in Frequency Domain
Tuning of PID Controllers
Power Factor Meter Principle
DCS Vs PLC
DCS versus PLC Architecture
IoT Project Ideas for Beginners - Internet of Things
100 IoT Project Ideas for Beginners – Internet of Things
