Reading: Industrial Automation System Architecture Reference Model
Inst Tools > Blog > Control Systems > Industrial Automation System Architecture Reference Model
Last updated: November 17, 2019 8:29 pm
Control Systems
3 Min Read
Architectures represented are based on the IEC 62443 Industrial Automation and Control Systems (IACS) architecture reference model. The basic model consists of 5 levels.
System ArchitectureLevel 0:Level 1:Level 2:Level 3:Level 4:Architecture Diagram Notations
System Architecture
Industrial Automation Architecture reference model
Figure 1: An Architecture reference model
Level 0:
It is the Process or equipment under control
Level 1:
It includes the Controllers/PLCs that provide basic control, safety and protection functions
Level 2:
It includes supervisory control functions and includes devices such as HMIs, Operating workstations, Engineering Workstations, Historians, Application Servers, Engineering Databases, etc.
Level 3:
It includes the operations management functions such as domain controller, backup server, antivirus and patch management, etc.
Level 4:
It refers to the Enterprise systems
  • The architecture diagrams show a very simplistic view of system architectures.
  • These architecture diagrams illustrate specific ways to perform remote access.
  • The local “IACS” network is represented simplistically to ease the understanding (the actual internal IACS architecture will vary and specific integration and interfaces between the diverse IACS usually required in most implementation is not included or represented in these diagrams).
  • Dataflows between the different functions are represented by arrows. The direction of the arrows show the outbound or inbound characteristic of the dataflow, but do not represent network sessions.
  • HMI is used as a generic term to refer to any Human Machine Interface or workstation (Operator, maintenance or engineering workstations, for BPCS, SIS, or Packages).
  • Local station refers to any workstation or server located at the production site that is used to transfer data or is accessed from a remote site.
  • The DMZ firewall is represented as a single symbol but can be implemented as a pair of physical firewalls.
  • The tunnel shown on the diagram refers to a secure tunnel, that can be set up with different technical solutions (e.g., IPSec).
  • These architecture Diagrams do not show the full detail of all possible types of local networks. Depending on the system vendor solution, some networks that are represented as the separate networks (such as control and HMI network) may be a single network.
Source: International Association of Oil & Gas Producers
Acknowledgments: IOGP Instrumentation and Automation Standards Subcommittee (IASSC) Remote Operating Centres Task Force.
  • Commissioning Documents
  • What is Process Control?
  • Cascade Control Loop Analysis
  • Direct Digital Control System
  • PID Controller Principle
Distributed Control System Objective Questions
What is a Transducer ?
Relation Control System
What is Advanced Process Control (APC)?
Process Dynamics and PID Controller Tuning
Compressor Emergency Shutdown Root Cause Analysis
Hardwired I/O and Serial I/O – Differences Explained
Difference between Fieldbus, Profibus and HART Protocols
Integral Controller Principle
DCS Alarm Summary Dashboard using Microsoft Power BI
Library of PlantPAx Process Objects
PID Controller Functions
30 Concerns for Control System Philosophy (Industrial Automation)
PROFIBUS is also a Master Slave protocol
Industry 4.0 Explained
Industry 4.0 Explained – Industrial Internet of Things
DeltaV Tune Tutorial
How to Tune a Loop in DeltaV System
Chart Recorders
What is a Recorder ?
Hot Well Level Control System in Condensing Turbine
Flapper nozzle system
Flapper Nozzle Questions
Electric Motors Noises
Electric Motors Noises – Types, Possible Sources, Reasons
Pressure Gauge Functional Testing
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
How to Calibrate Load Cells
Shockley Diode Working Principle
PID control block located in fieldbus transmitter
Foundation Fieldbus Device addressing
Pipeline Project Management
