Reading: Importance of Unit Measurement
Inst Tools > Blog > Calibration > Importance of Unit Measurement
Any measurement has two parts – a number and a unit of measurement. The unit of measurement is very important in calibration.
Last updated: September 28, 2022 3:26 pm
Saurabh Vaidya
Calibration
Measurement without units is useless. The unit of measurement is very important.
Importance of Unit MeasurementExamplesThe Gimli GliderMars Climate Orbiter
A measurement tells us about the property of something. It tells us how heavy an object is, or how long an object it is. A measurement gives us a number to that property.
Examples
For example,
The length of the wire is 1 meter. 1 is number and meter is the unit of measurement.
The weight of a man is 60 kg. 60 is number and kg is unit.
Also, weight is measure in pounds.
The weight of a man is 60 pounds. Here, 60 is the number and pounds is the unit.
However, 60 kg is not equal to 60 pounds. Even though both units are of weights, kg and pounds are not equal. So we can’t compare these units directly.
1 pound = 0.45 Kg, 60 pounds = 27.21 kg
For comparing anything both quantities should have the same units.
The following examples show the importance of the unit in measurements. And what happens if the unit is not the same while comparing them.
The Gimli Glider
An Air Canada Boeing 767-233 jet was refueled in Montreal using 22,300 pounds of fuel instead of 22,300 kilograms. The pilot calculated how much fuel he needed thinking he was getting his fuel in pounds per litre.
When the plane ran out of fuel mid-flight, the pilot had to make an emergency ‘gliding’ landing at Gimli Canadian Air Force Base. As only 10115 kg (22,300 pounds) of fuel is refuel instead of 22,300 kg of fuel.
The Mars Climate Orbiter was a 638-kilogram, on September 23, 1999, communication with the spacecraft was lost as the spacecraft went into orbital insertion, due to ground-based computer software which produced output in non-SI units of pound-force seconds (lbf·s) instead of the SI units of newton-seconds (N·s) specified in the contract between NASA and Lockheed.
The spacecraft encountered Mars on a trajectory that brought it too close to the planet, and it was either destroyed in the atmosphere or re-entered heliocentric space after leaving Mars’ atmosphere.
 NASA’s Mars Climate Orbiter programming teams in Europe and the USA used two different measurement systems, imperial and metric, to calculate the trajectory of the spacecraft. The probe consequently entered the Martian atmosphere at the wrong angle and promptly disintegrated.
Even simple measurement mistakes can be very costly!
Also, No measurement is complete without Uncertainty.
  • Importance of Vibration Measurement
  • Actuators Questions and Answers
  • Importance of Flow Meter Turndown Ratio
  • The Importance of Electrical Safety
  • Basics of Hydrostatic Level Measurement
Sand Probe Functional Testing
Pressure Gauge Functional Testing
Pressure Switch Calibration Procedure
What is a Dry Block? – Parts of the Temperature Calibrator
Flow Meter Calibration
Instrument Maintenance and Calibration System
  • Kayla says:
    April 1, 2022 at 11:44 pm
    What is the date of this article?
    I am doing a debate on the metric system. And the material I use needs to be recent.
As-found and As-left Documentation during Calibration
Magnehelic Gauge Calibration
Solenoid Valve Functional Testing
How are HART instruments Calibrated?
Differential Pressure Switch Calibration Procedure
Displacer (buoyancy) Level Transmitter Principle, Limitations, Design, Installation & Calibration
Dissolved oxygen probe calibration procedure
Calibration of Pyrometers using Black Body
Capacitance Level measurement principle
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Calibration & Preventative Maintenance Procedures
Calibration and Preventative Maintenance Procedures
Pressure Safety Valves Functional Testing
Pig Signalling Switches Functional Testing
Multiple Position Calibration of Temperature Chamber (Mapping)
Sensor Trim and Output Trim in Smart Transmitter
What is Sensor Trim and Output Trim in Smart Transmitter?
DP Transmitter Capillary arrangement
Common Mistakes in Dead Weight Tester
Common Mistakes to Avoid When Using Dead Weight Tester
Pressure Safety Valve Leak Test Procedure
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Password Protect Apps and Files
Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Instrument Steam Pressure Taps Primary Block Valves Glands and Bonnets Leaks
Single Phase Voltage Source Inverter Quiz
non-contact pyrometer principle
Non-contact Temperature Sensors
Logic Gates and Truth tables
Difference between Motion Controller and PLC
Control Valve Tubing
Instrument Tube Bending
