Reading: How to use Converters in PLC
Inst Tools > Blog > PLC Tutorials > How to use Converters in PLC
Last updated: March 4, 2021 3:27 pm
3 Min Read
To study the working of Converter (BCD TO INT/ INT TO BCD) in Allen Bradley programmable logic controllers (plc).
Integer to BCD Converter Block DiagramBCD to Integer Converter Block DiagramINTEGER TO BCD CONVERTERExample PLC Program: BCD TO INTEGER CONVERTER Example PLC Program: Conclusion:
Integer to BCD Converter Instruction in PLC
Block Name : TOD (Integer to BCD Converter )
In the above picture, there are totally two parameter,
SOURCE – Integer Value address
DESTINATION – BCD Value address
BCD to Integer Converter Instruction in PLC
Block Name: FRD (BCD to Integer Converter )
SOURCE – BCD Value address
DESTINATION – Integer Value address
In Allen Bradley RS500 Ladder logic, Integer to BCD converter block is called as TOD.
It will convert the integer to respective BCD Value
Ex:
Integer-1020
BCD– 0001-0000-0010-0000
PLC Program for BCD Conversion
Rung 0000 :
I:0/0 giving input condition to BCD converter. When it goes ON, value placed in N7:0 is converter into BCD and store the value in B3:0.
Rung 0001 :
Equal comparator block is used to give output to O:0/0 when B3:0 equals B3:1.O:0/0 is enabled because B3:0 and B3:1 are 0.
PLC Conversion Program
PLC Data File for Integer
PLC Data File for Binary
Rung 0000 :
I:0/0 giving input condition to BCD converter. When it goes ON, value placed in N7:0-1926 is converter into BCD (0001100100100110) and store the value in B3:0.
Rung 0001 :
O:0/0 is turned off  because B3:0 and B3:1 are not equal..
In Allen Bradley RS500 Ladder logic,  BCD to Integer  converter block is called as FRD.
It will convert the BCD to respective Integer Value
Ex:
BCD– 1001-1001-1001-1001
Integer-9999
PLC Logic for BCD to Integer Conversion
Rung 0000 :
I:0/1 giving input condition to INT converter. When it goes ON, value placed in B3:2  is converter into INT and store the value in N7:1.
Rung 0001 :
Equal comparator block is used to give output to O:0/1 when N7:1 equals N7:2.
O:0/1 is enabled because N7:1 and N7:2 are 0.
Example PLC Program for Binary Conversion
Data File for PLC
Data Display in PLC
Rung 0000 :
I:0/0 giving input condition to INT converter. When it goes ON, value placed in B3:2-0001010001010010 is converter into INT -1562 and store the value in N7:1.
Rung 0001 :
Equal comparator block is used to give output to O:0/1 when N7:2 equals N7:1.
O:0/1 is turned off  because N7:1 and N7:2 are not equal..
 Conclusion:
We can use this explanation to understand the working of Converters in Allen Bradley programmable logic controllers (plc).
Author : Hema Sundaresan
Timers Ladder Logics
Down Counter Ladder Logics
Convert Voltage to Current
Multiple Speeds with PLC
Retentive Timer using PLC
Compare Servo Motor and Stepper Motor
PLC Mixing Process with Adjustable Timer and Valve Control
PLC Program for Password Management using Structured Text
Parking Lights PLC Program Explained with Video
How to Use the Shift and Rotate Instructions in PLC?
Safety Door Interlock PLC Program
Why Use a Current Loop?
How to use Sub Routines with Allen Bradley PLC
What is CODESYS? Why Do You Need to Learn it?
PLC Structured Text Program for Output Generation via Equations
On Delay Timer TON in Tia Portal
Timers in PLC Programming – Siemens Tia Portal Tutorials
PLC Program
Example PLC Program
LES and GRT Blocks in PLC Programming
Allen Bradley Math Functions
Top 100 PLC Objective Questions and Answers
PLC Program with 2 Toggle Switches and 4 Motors
Automation Engineers Interview Questions
Allen Bradley PLC Interview Questions & Answers
Allen Bradley PLC Interview Questions and Answers
How to Use Symbol Factory Software for Graphic Design in HMI or SCADA
How to Use Symbol Factory Software for Graphic Design in HMI or SCADA?
Feedforward control with feedback trim
Feedforward Control Principle
GuideLines for Loop Checks
How to Do Loop Checks During Plant Pre-Commissioning
Saybolt Viscometer
Saybolt Viscometer
Thermowell Installation near Critical Equipment
Relay Internal Parts
Relay Operation, Types, Symbols & Characteristics
Why Baud Rate is Important in Modbus Network
transformers-questions-answers-part-1
Transformers Questions & Answers Part-1
