Reading: How to Save a PLC Project to a Micro Memory Card?
Inst Tools > Blog > PLC Tutorials > How to Save a PLC Project to a Micro Memory Card?
If you already have a memory card inserted in the CPU, then while downloading one copy of the PLC program will automatically be saved to MMC.
Last updated: March 4, 2021 11:23 am
2 Min Read
In this article, we will learn about a method to save the project to a micro memory card.
Micro memory card (MMC) is used to store a PLC project which you have downloaded to the CPU.
If you already have a memory card inserted in the CPU, then while downloading one copy of the program will automatically be saved to MMC.
Save a PLC Project to Memory Card
To save the project manually to the MMC, do follow the below steps.
Note that these steps are only going to work with actual PLC.
Step 1:
Open Simatic manager.
Open an existing project or create a new one.
Go to the main Simatic manager window as shown in the below window.
Step 2:
To save the project, select CPU and click on PLC, select an option save to MMC as shown in the below window.
Save to Memory Card
Step 3:
The following pop up will open.
Here, in step 7 data, the 1st option is the current user program. If you tick mark this option then the only current project will be saved and whatever resides inside the memory will be completely deleted.
Be wise before choosing this option.
If you want to prevent your old data or project from deleting, then chose the second option “current project”, which not only saves the project but also prevents an older project from deleting.
Hit “ok” to proceed.
Save PLC Project to Memory Card
Step 4:
If the module is in RUN mode then the following pop up will open and says you have to put the module into the stop mode.
Click “retry” to proceed. Now, your project is saved to MMC.
Load PLC Program to SD card
Author: Suhel Patel
  • PLC Midline Instruction
  • Input and Output Tags
  • Siemens PLC Interrupts
  • Upload Siemens PLC
  • S7 300 CPU Backup
Sorting & Distribution Line PLC Programming – Advanced Logic
#6 PLC Best Practices – Validate Timers and Counters
PLC Program for Daily Production Record
Data Handling Instructions in PLC Programming
Why is 24 Volts Commonly used in PLC Systems?
How to Create New Project Using Simatic Manager
Rockwell PLCs for Large Scale Applications
Basics of Loop Checks
4-20mA Loop Power Supply Questions
PLC 1 Push Button to Turn ON or OFF 1 Output
PLC Ladder Logic for Lube Oil Pump Motor
How Could FB and FC Make Me Professional PLC Programmer
How Could FB and FC Make Me Professional PLC Programmer?
Pneumatic valve operation in sequence mode
Sequential PLC Programming for the Pneumatic Valves
PLC Program for Forward and Reverse Motor control
3 Phase Motor Control using PLC Ladder Logic
Smart Drip Irrigation System Using PLC
Batch mixing process automation with Omron PLC
Automate Batch Mixing with Repeated Cycles in Omron PLC
Smart DP transmitter Formula
DP Transmitter Error Calculations
Fish Farm Automation
Omron PLC Project: Fish Farm Automation Tutorial
Thyristor Rating Objective Questions and Answers
PLC Program for an Alternate output circuit
Good and Bad Wiring Practices
Calibration Standards
Practical Calibration Standards
Advantages and Applications of zigzag transformer
Globe Valve Disk and Stem Connections
Globe Valve Seat and Disk
