Reading: How to Control VFD with PLC using Ladder Logic
Inst Tools > Blog > PLC Tutorials > How to Control VFD with PLC using Ladder Logic
Last updated: March 4, 2021 3:16 pm
7 Comments
This is a complete tutorial about PLC ladder logic to control variable frequency drive (VFD) for motor speed control with speed selection from Field Local Panel or SCADA graphics.
How to Control VFD with PLC ?Control and Power DiagramCommissioning and Parameters Programming in VFD PLC ProgramNetwork 1 :Network 2 :Network 3 :Network 4 :Network 5 :Network 6 :SCADA DesignNormal StateRunning StateError State
Execution Steps :
  1. Prepare a Control and Power drawing
  2. Commissioning and Parameters Programming in VFD
  3. Prepare a PLC program
  4. Prepare a SCADA design
VFD connections with PLC
  • Commissioning is needed for the proper function of VFD.
  • Necessary parameter like Motor Nameplate details, Input Voltage, Motor Type, Frequency should be entered in VFD during quick commissioning.
  • After successful quick commissioning, now it’s a time to install the advanced commissioning. This commissioning is needed to give the details of all the digital and analog inputs and outputs, like
    • Information about Digital inputs of Start command and Speed Selection command
    • Information about Digital Outputs like Status of Drive Running and Drive in Fault etc.
    • Information about Analog Inputs like Speed Input 1 and Speed Input 2
    • Information about Analog Outputs like Current and Frequency of Motor
 PLC Program
Network 1 :
VFD Ready to Start
In this Network 1, we are checking whether the VFD is ready to start. This signal will come when all the conditions are healthy as well as safety and power feedbacks are active.
Network 2 :
VFD Start Button in Ladder Logic
In the Network 2, When start button is pressed, VFD Drive_DO bit will be set, if Ready_to_Start and No Error will be there.
Network 3 :
VFD Stop Logic in PLC
This is the stop logic, When stop button is pressed it will reset the Drive_DO bit.
Network 4 :
VFD Run Feedback Fault PLC Logic
In this Network 4, this logic is required for safety as soon as Drive_DO bit will set and if any case VFD will not operate due to any fault then after predefined wait time, here we considered it as Run_FB_Time, it will reset the Drive_DO bit and generate Error.
This Error you can acknowledge from the SCADA after resolving the error from the field side.
Network 5 :
Variable Frequency Drive Overload Error Logic
In this Network 5, If the VFD is taking more current and gives overload error, then it will reset Drive_DO bit and generate Error.
Network 6 :
Drive speed selection Ladder Diagram
This is the speed selection Digital output, if you select speed input as a local then it will not activate Speed Selection bit resulting Speed_DO absent and if you select speed input as a remote then it will activate Speed Selection bit resulting Speed_DO present.
SCADA Design
Normal State
SCADA Normal State
This is the normal state of motor. There is no error as well as Ready bit is also in normal state.
Also the speed selection is in LOCAL mode.
Running State
SCADA Running State
This state shows that Ready bit is high and motor is running without any error.
Error State
SCADA Error State
There is an error bit is high and motor also showing error condition.
Note :
In some industries, Yellow color also used to indicate the error condition. Red color is used to indicate motor stop condition.
Author : Hiral Patel
PLC Logic for Oil Pump Motor
Car Washing using Ladder Logic
PLC Sequencer Programming
One Shot Falling Instructions
Ladder Logic for Tanks Filling
PLC Analog Input Card Resolution Effects on Accuracy
PLC based Auto/Manual Operation of Roll down Shutters in Industry
What is PLC Redundancy?
ESG in Industrial PLC Automation Systems
How to Add Unspecified CPU in Tia Portal?
7 Comments
  • Satish says:
    August 15, 2019 at 6:28 pm
    Good program
  • tosif mansuri says:
    August 16, 2019 at 4:01 pm
    Good
  • Jitendra nath nayak says:
    August 16, 2019 at 8:57 pm
    Communication btn drive & plc
  • sridhar says:
    June 25, 2020 at 10:39 am
    nice explanation
  • Suresh Kumar says:
    January 24, 2021 at 11:53 am
    Nice program logic
  • biraj says:
    February 25, 2022 at 12:53 pm
    this is a great site, it would be more systematic if the course contents were shown from zero to advance
  • Heybar Sequera says:
    January 29, 2023 at 2:15 am
    What do represent Temp1 and Tem2 on the Networks 2 & 3?
    Thanks in advance.
Allen Bradley RSLogix 500 PLC Programming
PLC Program for Water filling and Discharging Process
MCQ on PLC (Programmable Logic Controller)
80+ PLC MCQ Questions
PLC Interlock Logic with First Input Priority
Sorting & Distribution Line PLC Programming – Advanced Logic
Current to Voltage Conversion Circuit
How to Convert Current to Voltage using Resistor ?
PLC Sequence Programming Ladder Logic
Communicating Delta PLC Software to Simulator
How CPU Execute Program in Siemens PLC?
Basics of PID Controllers
PID Controllers in Closed Loop Control Systems – PLC Basics
SR Flip Flop Logic
How to implement SR Flip Flop using PLC Ladder Logic
Liquid management using PLC programming
PLC Programming for Loss in Weight Liquid Systems
How Weigh Feeder Works
How Weigh Feeder Works ?
Typical Purging Installation
Purging of Instruments
strain gauge changes as it stretches and shrinks
Why Strain Gauge Resistance Changes as it Stretches and Shrinks?
Induced EMF
Magnetic Circuits
How Does an Infrared Thermometer Work
How Does an Infrared Thermometer Work?
testing-thermocouples-and-rtds
Testing thermocouples and RTDs using Multi-function Calibrators
NAMUR OPEN ARCHITECTURE
Cable Glands
Using of MCT instead of Cable Glands on the Cabinets
Types of Wireless Technologies in Industrial Automation
