Reading: HMI Screen Design for Hazardous Applications
Inst Tools > Blog > PLC Tutorials > HMI Screen Design for Hazardous Applications
In this article, we will learn the design standards to consider for HMI screen design in hazardous areas with PLC applications.
Last updated: May 23, 2023 11:11 am
Industrial automation is majorly divided into two types of categories in terms of safety – hazardous and non-hazardous. Hazardous applications, as the name implies, regard a lot in terms of worker safety, environment safety, operational hazards, and machine safety.
So, it is most important to deal properly with them; because not only application constraints, but hazardous applications also deal with safety constraints. When you use graphical displays like HMI in a hazardous application, utmost care must be taken to design them efficiently.
Siemens Simatic HMI
This is because improper navigation and symbols can take a lot of time for the operator to troubleshoot, and this can badly hamper the maintenance and commissioning activities. In the worst case, if it is not handled properly and attended to on time, then it can even cause damage to human life.
The first step in designing HMI is taking care of the header and footer. An operator will always require quick access to the processes, diagnostics, and settings. So, if you give all the necessary buttons in the header and footer, then the operator can easily go to any screen in a quick time.
In the below image, you can see that all the important buttons, which will be used in the whole HMI navigation, like – user status, login, logout, IO status, mimic view, process selection, alarms, trends, settings, and plant status; are shown in the header and footer.
Basic HMI Screen
Also, apart from this, an alarm banner is shown in the header. You must be thinking that when we are already giving a button to view the alarm status screen, why this separate banner?
Well, in any critical system, if any alarm occurs, then it would be helpful if the user gets to see the alarm immediately without even touching anything. This saves time in troubleshooting. So, it is important to map all the critical buttons which will be used in the whole HMI program, in the header and footer.
The next step in designing is to give standard colors to the equipment used for indicating its off-state, on-state, and trip-state. Most of the users denote red color even in trip conditions. It would be very helpful if we indicate yellow color for trip indication. This will help the user in distinguishing between off-state and trip-state; prompting immediate action.
Otherwise, the operator will have to check the alarm screen every time to find out why a device is not working; because in both the cases of off and trip, the equipment is off and not running.
Refer to the below image for understanding, where a pump has been used and it will be animated by three color states for the corresponding stage. Easy color identification from a distance helps the user to monitor the plant more efficiently.
PLC HMI systems for hazardous areas
Next thing comes a faceplate. When the user finds any alarm or if he wants to just generally the status of equipment, a faceplate should be created, as shown in the figure.
A faceplate is a common box that opens when someone clicks equipment. This enables them to see or operate that equipment on that page only, rather than moving here and there. This makes troubleshooting easier and more efficient.
Also, in case of an alarm in the equipment, try to highlight a symbol near it. The symbol, like shown as a yellow triangle in the image, depicts some sign to be attended by the user for that corresponding equipment.
From this whole design, you can see how a user can easily navigate and operate the system with a single screen. If there are multiple HMI screens designed in a system and if the user has to navigate every time a lot, then for such hazardous and critical applications, the operator will take a lot of time to troubleshoot.
  • Types of Tags in SCADA
  • SCADA and HMI Systems
  • Delta HMI and VFD Logic
  • PLC Best Practices and Tips
  • What is Contextual HMI?
Features of SCADA
System and Local Time in PLC
Difference Between CompactLogix and ControlLogix
Why is 24 Volts Commonly used in PLC Systems?
Your First Steps Through STL Language
PLC Program for Automatic Bottle Rejection System
Establishing a Modbus Driver for SCADA Indusoft Web Studio
Push button Motor PLC Logic
PLC Programming Example on Timers Function Block
Comparison Instructions in PLC Programming
PLC Analog I/O Potential Problems – Troubleshooting & Issues
Hardwired IO and Serial IO - Differences Explained
Hardwired I/O and Serial I/O – Differences Explained
Exhaust Fan Control
Exhaust Fan Control: Example of PLC Timer Programming
How to Blink Lights in Ladder Logic
How to Blink Lights in Ladder Logic?
PLC Valve Control Example
Create a Function (FC) for a Valve Logic in Siemens PLC
VFD Commissioning and Testing Procedure
Communication between Factory IO and Siemens Tia Portal
Parking Garage Indicator PLC Automation
Parking Garage Indicator: PLC Automation System
SIS Fault Tolerance
SIS Hardware Fault Tolerance – Methods to Overcome HFT issues
Ph Meter Principle
pH measurement
PLC Program for Trash Compactor
Magnitude Comparator Objective Questions
Air Cylinder Consumption Calculation for Control Valves
Types of Motor Enclosures
Smoke Detection System Questions
Interview Questions on Smoke Detection System
Microprocessors Objective Questions – Set 3
