Reading: Guided Wave Radar Level Sensor Pressure and Temperature Effects
Inst Tools > Blog > Instrumentation Design > Guided Wave Radar Level Sensor Pressure and Temperature Effects
Last updated: July 7, 2020 12:58 pm
Instrumentation Design Level Measurement
2 Min Read
High pressures/temperatures reduce the propagation velocity of the measuring signals in the gas/vapour above the liquid interface to be measured. The result of the high pressure/temperature is a systematic measuring error.
Table gives several measuring errors for different gases/vapours.
Table – Example of measuring error on wave radar with high pressure/temperature
These errors may be compensated with two main methods:
  • compensation with external pressure and temperature sensors
  • compensation with a reference signal.
Compensation with external pressure and temperature sensor is achieved by calculation with external pressure and temperature sensors.
Compensation with a reference signal means that the actual wave velocity is measured by calculating a reference reflection between two known points a known distance (Lref) and relevant transit time.
Lref = Actual Velocity × Transit time of this Lref.
Having this Actual Velocity in the media, the distance can be calculated from the actual reflection time measurement. The Lref should be upper the higher maximum interface level with a margin (e.g. 150 mm in Figure).
Guided Wave Radar Level Transmitter Compensation
Figure – Example of high pressure/temperature compensation with reference signal mounting arrangement
Source: International Association of Oil & Gas Producers
Acknowledgements: IOGP Instrumentation and Automaton Standards Subcommittee (IASSC), BG Group, BP, Endress + Hauser, Emerson, Honeywell, Krohne, Petrobras, PETRONAS Carigali Sdn Bhd, Repsol, Siemens, Statoil, Total, Vega, Yokogawa.
Instrumentation and Control (I&C) General Specifications
Guided-Wave Radar Instruments Diagnostics
Ultrasonic Tank Gauging
Competency Factors of Instrument & Control Engineer (Design Engineering)
Magnetic Float Level Transmitter Working Principle
Capacitive Level Switch Principle
Gas Detectors Installation Techniques
Level Instruments Design Rules
Process Control & Safety Systems Logics Implementing Cycle
Difference between Intrinsic Safe and Non-Intrinsic Safe Cables
How to Select the Right Panel Enclosure for Your Application?
How to Select a Inductive Proximity Sensor
Level Indicators Working Principle
5 Most Common Mistakes When Specifying Valves
Dip Tape
What is Dip Tape Level Measurement?
Capacitance Level measurement principle
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Float & Dial Level Gauge Principle
Differential Pressure Transmitter Wet Leg Compensation
Differential Pressure Transmitters Compensated Leg Systems
Float level gauge Principle
Float Type Level Indicator Principle
Closed Tank Level Measurement using DP Transmitter
How can we use a DP Flow Transmitter for Level Measurement
Why Measure Level
Difference between Absolute, Gauge and Differential Pressure Transmitters
Online time of the PLC
System and Local Time in PLC
Safety Control System
What is Safety Control System ?
Functional Block Diagram in PLC for Oil and Water Process
Synchronous Machines Power Factor Control Questions
What is Fail-safe in Siemens PLC?
Diaphragm Seal Transmitters Errors
Certified Automation Professional (CAP) Exam Questions
