  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: FB Block in Siemens PLC Programming
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > FB Block in Siemens PLC Programming
Last updated: March 4, 2021 12:35 pm
This article is about the FB block which we use in Siemens PLC programming.
Function block (FB) is used to make the programming task easier. It is like subroutine which we have seen in Allen-Bradley PLC.
To stop writing the program over and over, it is a good practice to write the program in Function Block and call that program on-demand from OB.
The function block is configured to accept input from the main OB and write the output based on the execution of the FB.
FB is like FC with one difference in that is FC has overall memory space and doesn’t require any extra block to store that value whereas in FB it requires DB (Data Block) to store values. For each new FB, a new DB is required.
To understand how FB works, I will explain it using a simple example.
FB Block PLC Programming
Let’s first learn how to create FB, to do that so follow the below steps.
  1. Open the TIA PORTAL environment.
  2. Go to “PLC programming” and select “Function Block” and click on “add”.
Open TIA PORTAL environment
  1. The following window will pop-up, you can see here in the red square new block is added.
PLC programming and Function Block
Let, write PLC program for pet bottling process, where a bottle is getting rejected due to some issue like the cap is torn, weight is less or the cap is not properly fitted, etc.
The rejected bottle is automatically sent to the rejection conveyor. Now rejection ratio is too higher which fills till a proximity sensor activates in terms of sound alarm.
Let, assume we have 4 to 5 same rejection conveyor and I want to write the program. Now instead of writing the same logic over and over I will write the program in FB and call each time when OB executes.
  1. Here in the FB environment, you can find different options to write input and output as you can show in the figure.
How to Use FB Block in PLC Programming
  1. For our example, let consider 2 inputs and one output for alarm as shown in the below window.
Program Blocks in Siemens PLC
  1. In the below window you can see the program which I have written for rejection conveyor. Each time conveyor fills, the proximity sensor will turn ON which results in turning ON alarm.
A reset button is used to reset the alarm. Here, I have used alarm_1 as a latching in both input and output side because you can’t define output ALARM as input in FB block.
  1. To insert/add the above logic into the main OB we simply have to open the OB environment and have to drag FB block to OB.
As soon as you move FB to OB you will receive a pop-up as shown in the below window.
Here, you have to define the DB block as a memory space of FB. Click on “ok” to add DB.
siemens function block programming
  1. Here, by hitting ok the program will be added to OB as shown in the below window.
tutorial of siemens step-7 plc programming using simatic manager
  1. Define input and output. Whenever OB is executed it will call FB and Alarm will generate.
We can add other conveyor’s input and output here and each time any input gets activated, it will call FB and alarm will sound. Resetting the output will reset the alarm.
siemens plc db addressing
  1. Here, you can see how DB looks like. Db here will store the value of the FB.
Siemens STEP 7 PLC programming
Author: Suhel Patel
  • Ladder Logic Examples
  • PLC, HMI, VFD, and Motor
  • Pulse Generation using Timer
  • Liquid Mixing PLC Logic
  • Alarm Acknowledge PLC
Product Painting PLC Program using Omron CX-Programmer
PLC Sequential Operation Example Program
MCQ on PLC (Programmable Logic Controller)
Difference between DCS & PLC Systems
208kSubscribersSubscribe
Recent Comments
Related Articles
Loss in Weight Liquid PLC System
Dosing Pump PLC Logic
Wood Sawing and Blower System PLC Control Design
Wood Sawing and Blower System: PLC Control Design
Free Omron PLC Programming Course in HINDI
DCS Alarm and Setpoint
Setpoints and Alarms in Control System
Industrial Networking Interview Questions
Industrial Networking and Wireless Interview Questions
If Else Statement in SCL Language
Configuration of Siemens Scada and PLC
PLC Automatic Irrigation System Ladder Logic Project
More Articles
Deaerator
What is a Deaerator? – Working Principle
Linear Programming in Excel
How to Do Linear Programming in Excel?
Insulating Material for Cable Requirements
Pipeline Project Management
Wave Trap in Power Line carrier Communication
What is a Wave Trap? – Power Line Carrier Communication
PLC Ladder Logic Questions and Answers
Hook-up Diagram for Pressure Gauge
What is Instrument Hook Up Diagram ?
Ultrasonic Level Measurement Questions and Answers
