Reading: Electrical and Electronics Circuit Measurement Objective Questions
Inst Tools > Blog > Electronics MCQ > Electrical and Electronics Circuit Measurement Objective Questions
In this article, you will find the electrical and electronic circuit measurement objective questions and answers to test your knowledge.
Last updated: February 18, 2022 5:59 pm
Electronics MCQ Instrumentation MCQ
16 Min Read
In this article, you will find the electrical and electronics circuit measurement objective questions and answers to test your knowledge.
The below list provides all the multiple-choice questions (MCQ) related to the circuit measurement.
1. Which of the following configurations extends the range of a voltmeter?
A)A capacitor in series with the meter movement
B)A capacitor in parallel with the meter movement
C)A resistor in series with the meter movement
D)A resistor in parallel with the meter movement
2. The d’Arsonval meter movement is based on which of the following principles?
A)Moving vane
B)Permanent-magnet moving-coil
C)Electrostatic
D)Electrodynamic
3. What value of ac is indicated by a meter scale?
A)Peak-to-peak
B)Peak
C)Average
D)Effective
4. Which of the following electrical quantities is measured by a wattmeter?
A)Energy
B)Current
C)Voltage
D)Power
5. What electrical property is measured with an ohmmeter?
A)Current
B)Resistance
C)Voltage
D)Power
6. Which of the following electrical quantities is measured by a watt-hour meter?
A)Energy
B)Power
C)Current
D)Voltage
7. A voltmeter should be connected in an electrical circuit in what manner?
A)In series-parallel with the load
B)In parallel with the load
C)In accordance with Lenz’s Law
D)In series with the load
8. The hair-springs in a d’Arsonval meter movement perform which of the following functions?
A)They aid the movement of the pointer when there is current through the meter
B)They keep the pointer in the position of the last indication when the current is removed
C)They make electrical connections to the meter movement
D)All of these answers
9. What is meant by the term “meter damping”?
A)Moistening the felt pads
B)Compensating for electromagnetic induced interference
C)Preventing excessive current through the coil
D)Smoothing the oscillations of the pointer
10. How should an ohmmeter be connected in an electrical circuit?
A)In parallel with the source
B)In series-parallel with the load
C)In parallel with the load
11. What portion of the ammeter scale should be used to take a final reading?
A)The lower half
B)The upper half
C)Anywhere on the meter face
D)The mid-scale portion
12. Which of the following meter movements will measure either ac or dc without the use of a rectifier?
A)d’Arsonval
B)Electrodynamic
C)Electrostatic
D)GMS
13. Which of the following safety precautions should be observed when a megger is used?
A)Always start with the highest scale selection of the meter
B)Do not use a dc megger to measure circuits that are powered by ac
C)Do not touch the meter leads when a measurement is being taken
14. Out-of-circuit meters have which of the following advantages over in-circuit meters?
A)They are lighter weight
B)They can be used on more than one device
C)All of these answers
D)They are more rugged
15. What area of an ohmmeter scale should be used when a measurement is taken?
A)Lower half
B)Mid-scale portion
C)Upper half
D)Anywhere on the meter face
16. Why is there a mirror on the face of a multimeter?
A)To aid in reducing parallax error
B)To illuminate the meter face
C)To compensate for the difference in ac and dc measurements
D)To reduce the friction between the pointer and the meter face
17. If the mirror on the face of a multimeter is used properly, where will the image of the pointer appear?
A)Barely visible on either side of the pointer
B)Clearly visible to the left of the pointer
C)Hidden behind the pointer
D)Clearly visible to the right of the pointer
18. When the current in a conductor is measured without the conductor being disconnected, which of the following meters could be used?
A)Transformer voltmeter
B)Multimeter
C)Hook-on voltameter
D)Induction wattmeter
19. Circuit measurement is used for which of the following purposes?
A)To increase the power used in a circuit
B)To discover the length and width of a circuit
C)To find the weight of a circuit
D)To determine the reason a circuit is not functioning properly
20. Which of the following safety precautions does NOT apply to a multimeter?
A)Never apply power to the circuit when measuring voltage with the meter
B)Be sure the meter is switched to ac for ac measurements
C)Deenergize the circuit before connecting the meter
D)Observe proper dc polarity when measuring dc
21. What electrical property is measured by an ammeter?
A)Voltage
B)Power
C)Resistance
D)Current
22. Electrostatic meter movements are used to measure which of the following current/voltage values?
A)Low current
B)Low voltage
C)High current
D)High voltage
23. Which of the following methods is used to dampen a meter?
A)Incorporate an airtight chamber containing a van
B)Install a fuse in one of the input leads
C)Provide a fluid reservoir and sponge arrangement next to the pads
D)Mount the meter in a mu-metal case
24. The electrostatic meter movement reacts to which of the following electrical properties?
A)Power
B)Current
C)Voltage
D)Resistance
25. An ohmmeter is used to check for which of the following conditions?
A)Overheating
B)Undercurrent
C)Continuity
D)Overcurrent
26. Which of the following safety precautions should be observed prior to connecting an ammeter into a circuit?
A)All of these answers
B)Switch to the highest range
27. Which of the following safety precautions should be observed when a voltmeter is used?
A)Connect the meter in series with the circuit
B)All of these answers
C)Start with the lowest range of the meter
D)Deenergize the circuit before connecting the meter
28. Which of the following safety precautions should be observed when an ohmmeter is used?
A)Deenergize the circuit before connecting the meter
C)Always start with the highest scale of the meter
D)Observe proper polarity
29. The ammeter with the greatest sensitivity has which of the following characteristics?
A)A high ratio of internal resistance to full-scale deflection indication
B)The lowest amount of current for full-scale deflection indication
C)The highest amount of current for full-scale deflection indication
D)A low ratio of internal resistance to full-scale deflection indication
30. A multimeter can be used to measure which of the following electrical properties?
A)Resistance
B)all of these answers
C)Current
D)Voltage
31. An in-circuit meter is used for which of the following purposes?
A)To control power to a circuit
B)To reduce circuit losses
C)To prevent circuit overload conditions
D)To monitor circuit operation
32. If a multimeter has no OFF position, and it is returned to storage, on which of the following positions should the meter be set?
A)Ac; highest current range
B)-dc; higher resistance range
C)+dc; highest voltage range
D)Ac; highest voltage range
33. What range of an ammeter should you use for an initial measurement?
A)The lowest range
B)The highest range
C)The mid-scale range
D)Any of these answers
34. One of the problems encountered in building a multimeter is that the meter movement gives different readings for the same values of ac and dc.​
Which of the following features of a multimeter will solve this problem?
A)An ac/dc switch
B)A rectifier
C)Separate scales for ac and dc
D)A mirror on the face of the meter
35. A d’Arsonval meter movement reacts to which of the following values of voltage?
A)Peak-to-peak
B)Peak
C)Average
D)Effective
36. Ammeters measure various ranges through the addition of which of the following components?
A)Capacitors in series with the meter movement
B)Shunt resistors in parallel with the meter movement Option 2
C)Shunt resistors in series with the meter movement
D)Capacitors in parallel with the meter movement
37. To keep the effect of a voltmeter on a circuit to a minimum, the internal resistance of the voltmeter must have which of the following relationships to the circuit load?
A)Lower than
B)Higher than
C)In proportion to
D)Equal to
38. How does an ammeter affect the circuit being measured?
A)It acts as a resistance in series and lowers the circuit current
B)It acts as a resistance in series and raises the circuit current
C)It acts as a resistance in parallel and lowers the circuit current
D)It acts as a resistance in parallel and raises the circuit current
39. Ohmmeter are classified by type. What are the two types of ohmmeters?
A)Series and shunt
B)Full- and half-scale
C)all of these answers
D)Normal and reverse
40. The function switch on a multimeter does NOT perform which of the following functions?
A)Changing of the multimeter from an ammeter to a voltmeter
B)Determination of the proper scale
C)Selection of the meter range
D)Selection of ac or dc capability
41. What electrical property is reacted to by the electrodynamic, d’Arsonval, moving vane, and thermocouple meter movements?
A)Resistance
B)Current
C)Power
D)Voltage
42. What voltmeter range should be used for initial measurements?
A)The mid-scale
B)The highest
C)None of these answers
D)The lowest
43. When a megger is used to check the insulation of a wire, which of the following indications should be considered normal?
A)​​500 V
B)​​1000 V
C)​​0
D)​​∞
44. How are ammeters connected in an electrical circuit?
A)In series with the load
D)In parallel with the load
45. What electrical property is measured by a voltmeter?
A)Resistance
B)Voltage
C)Power
D)Current
46. How is the effect that an ammeter produces in a circuit kept to a minimum?
A)By ensuring that the meter resistance is high compared to circuit resistance
B)By ensuring that the meter resistance is low compared to circuit resistance
C)By using a large capacitor in parallel with the ammeter
D)By using a large resistor in series with the ammeter
47. Which of the following types of meters can be made from a current sensitive meter movement?
A)Voltmeter
B)Ohmmeter
C)Ammeter
D)Each of these answers
48. Current through a meter results in the pointer.​
In d’Arsonval meter movement, what force produces this deflection?
A)Electrostatic repulsion
B)The interaction of magnetic fields
C)Thermocouple action
D)Mechanical spring tension
49. A voltmeter has an effect on the circuit being measured; what is this effect called?
A)Eddy-current drag
B)Loading
C)Rectification
D)Damping
50. When, if ever, can you use a dc ammeter to measure ac values?
A)Always
B)For low values
C)Never
D)When the ac is high frequency
51. What device allows a d’Arsonval meter movement to measure ac by converting ac to pulsating dc?
A)A pulsator
B)A rectifier
C)A converter
D)A modulator
52. Meggers (megohmmeters) are used to measure which of the following quantities?
A)High resistance
B)High voltage
C)Low voltage
D)Low resistance
53. An ohmmeter can measure different ranges because of the use of which of the following components?
A)Range potentiometers
B)Range resistors
C)Range coils
D)Range capacitors
54. A voltmeter has a high sensitivity when it has which of the following characteristics?
A)High deflection indication
B)Low ratio of internal resistance to full-scale deflection indication
C)High ratio of internal resistance to full-scale deflection indication
D)Low deflection indication
55. What is the most obvious differences in the two types of ohmmeters?
A)The ranges of the meters
B)The size of the test leads of the meters
C)The power sources of the meters
D)The scales of the meters
Click Here for Answers
Next Quiz:
  • Transducers MCQ
  • RTD Questions & Answers
  • Measuring Instruments MCQ
  • Industrial Instrumentation MCQ
  • Distributed Control System MCQ
Measurement of Resistance Objective Questions
Radio Telemetry Objective Questions
Vibration Probes Questions and Answers
Instrumentation Engineering Quiz – Set 2
Force Measurement Objective Questions
  • Jasthen navarro says:
    February 19, 2022 at 5:16 pm
    An exceptionally mind boggling exercise for average level practitioners
100+ Questions and Answers on Industrial Automation and Control
AC Fundamentals Objective Questions and Answers
Hall Effect Transducers Objective Questions
Pressure Measurement Multiple Choice Questions
Measurement of Voltage Objective Questions
Measurement of Phase Angle Objective Questions
Proportional Integral Derivative Controllers – PID MCQ
Sensors and Transducers Objective Questions
Electronic Devices & Circuits Quiz – Set 16
Test Questions on Safety Instrumented System
DC Power Supplies Objective Questions
Fiber Optic Measurement Techniques
Fiber Optic Measurement Multiple Choice Questions (MCQ)
Nuclear Plant Sensors and Detectors Quiz
Wet Contacts and Dry Contacts in PLC Systems
Instrument Technicians Tools - Instrumentation MCQ Questions
Instrument Technicians Tools – Instrumentation Test
Squirrel Cage Induction Motor Synchronous View
Squirrel Cage Induction Motor Animation
What is a transformer tap changer?
EcoStruxure Machine Expert - HVAC - Programming Software
How to Write a Program in Ecostruxure Machine Expert HVAC Software?
Boiler Protection System
Burner Management System Logic and Interlock
hydrostatic interface measurement calculation
Hydrostatic Pressure Measurement Questions
Automatic exhaust fan control
XG5000 PLC Programming for Automatic Exhaust Fan
Omron PLC painting program
Product Painting PLC Program using Omron CX-Programmer
