Reading: Distributed Control System Objective Questions
Inst Tools > Blog > Control Systems > Distributed Control System Objective Questions
Last updated: June 17, 2019 8:10 pm
Control Systems
3 Min Read
You can find the top 10 objective questions and answers on distributed control system (DCS). A quiz also available at the end of the article to practice the questions and evaluate yourself.
Distributed Control System QuestionsClick on below button to launch the Quiz.
Distributed Control System Questions and Answers
1. ________is the specific output of the controller is not uniquely determined by the error.
A) On off control
B) Multi-position control
C) Cascade control
D) Floating control
2. ________ is the elapsed time between the instant deviation occurs and when the corrective action first occurs.
A) Controlled variable
B) Dead time
C) Process
D) Hysteresis
3. A controller operates with ________ when an increasing value of the controlled variable causes an decrease in value of the controller output.
A) Either Direct or Reverse action
B) On off control
C) Direct action
D) Reverse action
4. A controller operates with __________ when an increasing value of the controlled variable causes an increasing value of the controller output.
B) Manipulated variable
C) Direct action
D) Reverse action
5. _________ refers to the time for the process control loop to make necessary adjustments to the final control element.
A) Manipulated variable
B) Control lag
C) Valve
D) Process
6. The two position control mode is best adapted to _________ scale system with relatively slow process rates.
A) Medium
B) Large
C) Any
D) Small
7. _________ is a complex assembly of phenomena that relate to some manufacturing sequence.
A) PLC
B) Controlled variable
C) Manipulated variable
D) Process
8. On-Off is the type of _________ Mode.
A) Precise Controller
B) Discontinuous controller
C) Continuous Controller
D) PID Controller
9. In process control the basic objective is to _________ the value of some quantity.
A) Regulate and Control
B) Control
C) Display
D) Regulate
10. _________control mode is used in an attempt to reduce the cycling behavior, overshoot, undershoot inherent in the two position mode.
A) Continuous
B) Multi-position
C) On off control
D) All of the Answers
This quiz section consists of total 10 questions. Each question carries 1 point. No negative points for wrong answers. You need to score at-least 50% to pass the quiz i.e. 5 Points. You can get Quiz Answers after submitting all questions.
MCQ
Also Practice Tests on : Instrumentation Quiz
Tuning a Temperature Process Control Loop
DCS Alarm Summary Dashboard using Microsoft Power BI
Purpose of Gateways, Bridges & Routers in Networking
Proportioning Feedforward action
Boiler Drum Level Control Systems
Control Modes of Air Handling Unit (AHU) – HVAC Basics
Speed Control of Ship Electrical Motor Propulsion
Steady-State Process Gain
Runaway Processes
What is Electromagnetic Noise Interference?
Tuning a Liquid Level Process Control Loop - 1
Alarm prioritization
What is Alarm Prioritization? – Types of Alarms
How to Train Your Maintenance Team for Industrial Automation Systems
Level Loop Troubleshooting
Identify Faults in PID Control Loop
DCS
DCS
Loop Power Indicator Principle
Basics of Loop Powered Devices
Nuisance Alarms
What is Alarm Shelving? – Nuisance Alarms, Types, Suppression
Tank level control system
Determining the Design Purpose of Override Controls
Quiz on Manual Motor Starters
100 Electromagnetic Motor Starters Multiple Choice Questions
Differential Pressure versus Flow Rate
Orifice Flowmeter Rangeability
Gas Holder Level Measurement
Measurements in Air and Fuel Circuit in Power Plant
Functions of Instrument Transformers
Functions of Instrument Transformers (CTs and PTs)
Tilting Pad Bearing
Three Phase Converters Quiz
Career Scope in Electronics Engineering
High Integrity Pressure Protection System HIPPS
Overview of HIPPS System
