Reading: Difference between PT100, PT1000, Nickel RTD and Balco RTD
Inst Tools > Blog > Guest Articles > Difference between PT100, PT1000, Nickel RTD and Balco RTD
Last updated: May 1, 2019 9:33 am
Guest Articles Temperature Measurement
2 Comments
1 Min Read
Comparison of Different RTD Types : PT100 Vs PT1000 Vs Nickel RTD Vs Balco RTD
Description Platinum RTD
100Ω wire
wound and thin
film
Platinum RTD
1000Ω thin film
Nickel RTD
1000Ω wire
wound
Balco RTD
2000Ω wire
wound
Cost –OEM quantity  High  Low Medium  Medium
Temperature range Wide
-400 to 1200°F
(-240 to 649°C)
Wide
-320 to 1000°F
(-196 to 538°C)
Medium
-350 to 600°F
(-212 to 316°C)
Short
-100 to 400°F
(-73 to 204°C)
Interchangeability Excellent Excellent Fair Fair
Long term stability Good Good Fair Fair
Accuracy High High Medium  Low
Repeatability Excellent Excellent Good Fair
Sensitivity (output) Medium High High Very High
Response Medium Medium to Fast Medium Medium
Linearity Good Good Fair Fair
Self-heating Very low to low Medium Medium Medium
Point (end) sensitivity Fair Good Poor Poor
Lead effect  Medium  Low  Low  Low
Physical size / packaging Small to medium Small to large Large Large
Article by : Naresh L
RTD Questions and Answers
Bridge Circuit Construction
What is a Probe Thermometer? How to Calibrate and Use it?
Calculate Temperature Coefficient of RTD
PLC Program for Entry and Exit Control of Car Parking
2 Comments
  • K Sreenivasan says:
    September 15, 2017 at 2:43 pm
    Normally PT100 rules the power/water industry
    Can you pl give some application where 1000ohm and 2000ohm RTDs are normally used?
  • E.ROYAN FRANK says:
    September 17, 2017 at 8:59 am
    Sir I am E.royan frank ,Iam Intending to start a coaching class for instrumentation .I need your permission to use your article as training materials.
    Thanking you
    E.Royan frank .
    7433036622
Thermocouple Temperature Measurement Errors
How RTD Measuring the Temperature
Capacitance Level Switch Calibration
Conductivity Transmitter Calibration Procedure
Pneumatic Temperature Transmitter with Sensor Principle
Testing a Thermocouple With a Multimeter
Ambient Temperature Effects on RTD
How to Calibrate Temperature Switch? – Instrument Basics
Three Wire RTD Circuit
What is a Three-wire RTD ?
Convert 2 wire RTD to 4 wire RTD Sensor
How to Convert 2 wire RTD into 3 or 4 wire RTD?
Loop Current Step Response (LCSR) Test for RTD
Response Time Test of RTD and Thermocouple
PLC Program for Automatic Bottle Rejection System
What is Temperature
What is Temperature ?
Thermocouple Reference junction compensation
Difficulties with Thermocouples for Temperature Measurement
What is Hydraulics
What is Hydraulics?
Thermovcouple Circuit
Thermocouple and its Principle
Basics of Loop Checks
Differential Pressure Flow Meters
Short Notes on Differential Pressure Flow Meters
Modern Instrumentation and Control Systems
Coaxial
Fiber Optic Cable vs Coaxial Cable
pressurized water reactor
SIS Example : Nuclear Reactor Controls
PLC Program for Positive edge pulse output for one scan cycle
PLC Program for Positive Edge Pulse Output for One Scan Cycle
Cable Glands
Using of MCT instead of Cable Glands on the Cabinets
