Reading: Why Counter-current Heat Exchangers are better than Co-current?
Inst Tools > Blog > Process > Why Counter-current Heat Exchangers are better than Co-current?
The counter-current heat exchanger is more efficient and better (in the same size) than the co-current is from the thermal driving force.
Last updated: May 8, 2021 12:55 pm
Process
3 Min Read
In general, engineers always try to design counter-current heat exchangers, unless for layout issues that force them to choose co-current ones.
Why Counter-current Heat Exchangers are better than Co-currents
This article tries to take a brief look at this question by using HYSYS and Tema standards.
Tema standard introduces the below formula to size a heat exchanger:
A = Q / ( U.f.LMTD)      ……equation (1)
In which
A = Required effective outside heat transfer surface, m²
U = Overall heat transfer coefficient, W. m-2. K-1
Q = Total heat to be transferred, W
LMTD= logarithmic mean temperature difference
f = LMTD correction factor.
Tema says that LMTD is:  equation (2)
Heat exchanger Tema standard formula
Where:
GTTD = Greater Terminal Temperature Difference.
LTTD = Lesser Terminal Temperature Difference.
But GTTD and LTTD are different in co-current and counter-current heat exchangers. In the image below these terms are defined for both.
Co-current and counter-current heat exchangers
According to the fist formula (1), for the same duty Q if the LMTD increases, the required surface A will decrease that will result in reduced cost.
It is exactly here that we can find the answer of the main question. Generally, the LMTD of the counter current heat exchanger is bigger than the co-current.
In the example below solved by HYSYS, you can see that the LMTD of counter-current type is bigger and therefore the AU (required surface “A” multiplied by coefficient “U”) is lower than the co-current type values in the same situation.
Heat Exchanger Worksheet
Heat Exchanger Performance
Thermal Driving Force
Another way to explain why the counter-current exchanger is more efficient (in the same size) than the co-current, is by looking at the definition of the thermal driving force.
The temperature difference is the driving force for heat transfer. There is always a big and homogenous temperature difference between two fluids in a counter-current heat exchanger but this difference of temperature is very low in the case of co-current exchangers at the end of the exchanger where two fluids exit.
Author: Hanif Yazdani
  • NPT, NPTF, BSPP, and BSPT
  • Electric Motor Actuator Parts
  • Heat Exchanger Temperature Control
  • Information on the Pressure Gauge Dial
  • Why we use Wheatstone bridge in RTD?
Backwashing
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Cooling Tower
Rotary Compressors
Pressurizer
Components of Water Treatment Plant
What is a Control Loop ?
Discharge Head 3‑monthly leaks of Steam Turbine Driven Centrifugal Compressors
Why Restriction Orifice is some distance from Blowdown valve ?
Blowout preventer (BOP) Principle
Backwashing Precoat Filters
Heat Exchanger Root Cause Analysis
Heat Exchanger Root Cause Analysis (RCA)
Flare KOD
Flare Knockout Drums Working Animation
swing check valve Theory
Hydraulic System
Working of Air Compressor
Working of Air Compressor – Types – Control Techniques
Process Control Terms
143 Process Control Terms and Glossary – Questions Answers
desuperheater
Desuperheater Design
Positive Displacement Pumps
What are Positive Displacement Pumps and their Types?
How to export in Vijeo Designer
Vijeo Designer software – Import and Export
Linear Approximation of the Non-Linear System MCQ
Feedforward control with feedback trim
Feedforward Control Principle
Capacitive Time Constant for Charging Capacitor
Analog Electronics Objective Questions – Set 1
Quiz on Thyristor Chopper
Packaging Machinery
Poor Bagging Scale Availability Threatened Production Cuts
RTD Construction
Introduction to RTDs
