Reading: Conveyor Operation with a Backup Motor using PLC Ladder Diagram
Inst Tools > Blog > PLC Tutorials > Conveyor Operation with a Backup Motor using PLC Ladder Diagram
In this article, you will learn the conveyor operation using the main motor and backup motor with PLC ladder diagram logic.
Last updated: September 28, 2022 2:22 pm
Hussien Ghareb
Continuity and reliability are essential advantages a plant or system can have. So, in this case, failures should be predicted and also you have to prepare a swift solution or actions for such a situation.
Explaining Conveyor OperationPLC Ladder Diagram using Siemens TIA Portal
Today we are going to have a simple common situation that is presented in most plants that contain some critical conveyors that cannot be stopped for any reason.
Here we have a very simple conveyor that is a part of a whole system.
The main problem is if this conveyor stopped the whole factory and the system operation will stop, that means increasing system downtime, and by its role that would cost you a lot of money.
To avoid such a situation, we are using a backup motor for some critical conveyors in some plants, all we need a backup motor that is connected with the same motion axe of the conveyor motor. As shown in Fig. (1)
Conveyor Control with Main Motor and Backup Motor
Figure 1
In case of failure of the main motor, the backup motor will work instead of it.
Register Siemens PLC Course: Click Here
We discussed the PLC ladder logic networks designed in the Siemens Tia portal.
Network 1: Controlling the Main Motor
Here we have the first network that is shown in Fig. (2) as we can see by clicking on (I0.0) we can start the main motor.
PLC Controlling the Main Motor
Figure 2
Notice that (I0.2) is the stop push button and it is already NC.
Also, we have an electrical interlock from the backup motor presented in (NC from Q0.1). to prevent the two motors from working together.
If the motor stops the bit (M0.2) would indicate that and it will stop the order of running that is presented on the digital outputs of the PLC signals.
Network 2: Controlling the Backup Motor
Then we have the second network that is shown in Fig. (3) as we can see by clicking on (I0.1) we can start the main motor.
PLC Control Backup Motor
Figure 3
Beside the motor latch (Q0.1) we can see a bit (M0.0) that also can operate the backup motor in case of failure.
If the backup motor stops the bit (M0.3) would indicate that and it will stop the order of running that is presented on the digital outputs of the PLC signals.
Network 3: Main Motor Latch
For this network that is presented in Fig. (4) we can see that if any failure (Motor Stoppage) is indicated on the main motor by this bit (M0.2), the bit of (the main motor latch “M0.0”) will be energized.
Main Motor Latch in PLC
Figure 4
Then as you can see in Fig. (3) this bit will operate the backup motor then when the backup motor is on (by its role) it will de-energize the main motor latch (M0.0) again.
Network 4: Backup Motor Latch
Here we have the last network presented in Fig. (5) we can see that if any failure (Motor Stoppage) is indicated on the backup motor by this bit (M0.3), this bit (the backup motor latch “M0.1”) will be energized.
Conveyor Operation with a Backup Motor using Ladder Diagram
Figure 5
Then as you can see in Fig. (2) this bit will operate the main motor back again then when the main motor is on (by its role) it will de-energize the backup motor latch (M0.1) again.
  • Scan Cycle in SIEMENS PLC
  • Cloud-Based SCADA Projects
  • PLC-based Gas Detection System
  • Create New Project in Studio 5000
  • Rockwell Allen Bradley PLC Projects
T Flip Flop PLC Ladder Diagram
Parts of PLC
SCADA Hardware and Software
Components of PLC
How to Automatically Close Pop-up in FactoryTalk View Studio?
Parking Garage Indicator: PLC Automation System
Everything You Need to Know About PLC Battery
What is Trace Function in Tia Portal?
Example PLC Program to Control a Pump based on Level Sensors
Static and Temp Variables in PLC
Which Connection is Best for PLC? – Sinking or Sourcing
PC-Based Motion Controller
Various Types of Delta PLC used in Industrial Automation
Modbus in Industrial Networks
PLC based Door Open and Closing System
Hardwired IO and Serial IO - Differences Explained
Hardwired I/O and Serial I/O – Differences Explained
PLC Programming Example with Pushbutton and Motor
Yokogawa DCS Tutorials - Configuration of Analog Input (Transmitter)
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
OPC in PLC Systems
OPC in Old PLC Systems
Advanced Skills Required for a PLC Programmer to Get a Job
What is an Altitude Valve
What is an Altitude Valve?
Measurement of Errors Objective Questions
Steam Turbine Interlocks
What are the Interlocks for Steam Turbine?
PLC Examples for calling functions in SCL
Introduction to SCADA
Encode and Decode Instructions
How to Use Encode and Decode Instructions in PLC ?
3 Phase Bridge Inverter MCQ
Digital Control Systems
Z & S Domain Relationship
