Reading: How to Convert Current to Voltage using Resistor ?
Inst Tools > Blog > Basics > How to Convert Current to Voltage using Resistor ?
Last updated: March 4, 2021 3:33 pm
Basics PLC Tutorials
3 Min Read
In this article, we discuss about How to Convert Current to Voltage using Resistor with different examples like 0-20 mA to 0-10 VDC Conversion, 4-20 mA to 2-10 VDC Conversion, 0-20 mA to 0-5 VDC Conversion.
Convert Current to VoltageExample : 0-20 mA to 0-10 VDC ConversionExample : 4-20 mA to 2-10 VDC ConversionExample : 0-20 mA to 0-5 VDC Conversion
It is extremely simple to measure 0-20 mA signal with a device that will measure only Voltage inputs. If the Voltage input module available will accept a 0-10 Vdc signal, but may not accept a 0-20ma signal directly.
Basically, Ohms law is used to calculate a resistor value in order to convert the 0-20ma signal to a voltage.
Current to Voltage Conversion Circuit
Ohms law states: R = V/I where V is the Voltage, I is the current and R is the resistance
R = 10V/0.020A = 500 Ohms
V = I*R = 0*500 = 0V
V = I*R = 0.020*500 = 10V
V = I*R = 0.004*500 = 2V
R = 5V/0.020A = 250 Ohms
V = I*R = 0*250        = 0V
V = I*R = 0.020*250 = 5V
Note:-
  • To avoid damage you must ensure that the external current source has short-circuit protection in all conductor cases.
  • The external resistor is a source of error because of its dependency on temperature and its inaccuracy.
  • In order to obtain measuring results that are as precise as possible it is recommended to use resistors with tolerances that are as small as possible.
Credits : myplctechnology blog
  • How to Connect a Solenoid Valve with PLC?
  • Redundant Power Supply for Critical Field Panels
  • How to Convert Voltage to Current using Resistor?
  • Gap Voltage of Bently Nevada Vibration Probe
  • Energy Conversion Quiz
PLC Techniques for I/O Mapping
Define the Order of Execution in Functional Block Diagram of Studio 5000
  • Habeeb ali says:
    August 20, 2021 at 9:05 pm
    Good to read
    And get good information for instrumentation
PLC Digital Input and Digital Output Modules
PLC SCADA Engineers Interview Questions and Answers
Unknown Do’s Need to Know as a PLC Programmer
Mitsubishi Electric GOC Controllers
PLC Program for Alarm Security System
PID with Practical Example
Batch Mixing with PLC Ladder Logic Program
WinCC data logging
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
Difference between Signal Cables and Control Cables
Example Program Logic in Allen Bradley PLC
PLC Programming Examples on Industrial Automation
Program to implement T Flip Flop logic
T Flip Flop PLC Ladder Diagram
Convert Raw Counts to Engineering Units
Raw Counts to Engineering Units : Conversion Formula
Programmable Logic Controller Practice Tests
OPC-OLE-for-Process-Control
What is OPC ?
PLC Karnaugh maps
How to Simplify PLC Coding Using Karnaugh Maps?
Delta WPL Soft Counter
Delta PLC Counter with Comparison
Identify Instrumentation Terms in Water Supply System
proximitor module
Bently Nevada Vibration System Verification Procedure
Why is HV Testing important in Electrical Panels?
Electrical Machines Interview Questions and Answers
Field Transmitter Range Calculation
Transmitter Turndown Ratio, Set Span and Zero Span
