Reading: Control Loops Objective Questions and Answers
Inst Tools > Blog > Control Systems > Control Loops Objective Questions and Answers
Learn about the control loops objective questions and answers in industrial automation which covers open-loop, closed-loop & PIDs.
Last updated: July 25, 2024 3:40 am
Control Systems Control Systems MCQ Instrumentation MCQ PLC Tutorials
8 Min Read
Control Loops Objective QuestionsWhat is the primary purpose of a control loop in a system?In a feedback control loop, what is the role of the controller?Which of the following is an example of an open-loop control system?How does a closed-loop control system differ from an open-loop system?What type of controller uses past and present errors to predict future errors?Why might a proportional controller alone be insufficient for some control systems?What is the main disadvantage of an open-loop control system?In a control loop, what is the function of the actuator?Which type of control system is most effective for dynamic and precise control?What is the benefit of using a PID controller over a simple proportional controller?What is the main advantage of a feedforward control system?In what situation is a feedforward control system most useful?How does a proportional-integral (PI) controller improve performance over a proportional controller?What is the main role of the derivative component in a PID controller?Which type of control loop is best suited for a system with frequent and significant disturbances?Why is an integral controller rarely used alone in control systems?In control systems, what does the term ‘setpoint’ refer to?What is a primary characteristic of an open-loop control system?Why might a control system use both feedback and feedforward control?What is the main purpose of the integral action in a PI controller?What type of controller is most commonly used in industrial process control?Which component in a feedback control loop measures the process variable?In what scenario is a derivative controller particularly useful?Why is a PID controller considered more effective than a PD or PI controller alone?What is a common application of an open-loop control system?
This video explains the detailed answers to the questions on the control loop. Let’s check the video and learn more.
Control Loops Questions and Answers - Control Systems Basics
Question 1
A. To amplify signals
B. To reduce noise
C. To maintain a desired output
D. To increase system speed
Show the Answer
Question 2
A. Adjusts the actuator
B. Measures the process variable
C. Compares setpoint with controlled variable
D. Generates the setpoint
Show the Answer
Question 3
A. Automatic washing machine
B. Light switch
C. Cruise control
D. Central heating system
Show the Answer
Light switch
Question 4
A. Continuously adjusts based on feedback
B. Operates without feedback
C. Uses no sensors
D. Has no setpoint
Show the Answer
Question 5
A. Derivative controller
B. Integral controller
C. PID controller
D. Proportional controller
Show the Answer
PID controller
Question 6
A. It is too complex
B. It causes instability
C. It ignores past errors
D. It does not respond to future errors
Show the Answer
Question 7
A. High complexity
B. Slow response time
C. High cost
D. Inability to correct disturbances
Show the Answer
Question 8
A. To process the control signal
B. To sense the process variable
C. To perform the desired action
D. To provide feedback
Show the Answer
Question 9
A. Manual control
B. Open-loop control
C. Feedback control
D. Feedforward control
Show the Answer
Feedback control
Question 10
A. Improved accuracy and stability
B. Lower cost
C. Faster response time
D. Simpler design
Show the Answer
Question 11
A. Simpler than feedback
B. Reacts to disturbances
C. Anticipates disturbances
D. Eliminates the need for sensors
Show the Answer
Question 12
A. When system dynamics are slow
B. When precision is not critical
C. When disturbances can be measured
D. When disturbances are unpredictable
Show the Answer
Question 13
A. Increases system complexity
B. Reduces response time
C. Reduces oscillations
D. Eliminates steady-state error
Show the Answer
Question 14
A. Simplifies the control system
B. Predicts future errors
C. Reduces the current error
Show the Answer
Question 15
A. Manual control
B. Closed-loop control
C. All of the options
D. Open-loop control
Show the Answer
Closed-loop control
Question 16
A. It is too slow
C. It cannot eliminate steady-state error
D. It ignores future errors
Show the Answer
Question 17
A. The input signal
B. The desired output
C. The maximum output
D. The current output
Show the Answer
The desired output
Question 18
A. Operates without feedback
B. Eliminates all errors
C. Uses feedback
D. Adjusts based on output
Show the Answer
Question 19
A. To combine anticipatory and corrective actions
B. To reduce complexity
C. To reduce cost
D. To eliminate the need for sensors
Show the Answer
Question 20
A. To eliminate steady-state error
B. To measure the current output
C. To predict future error
D. To speed up response
Show the Answer
Question 21
A. P controller
B. PID controller
C. I controller
D. D controller
Show the Answer
PID controller
Question 22
A. Actuator
B. Controller
C. Setpoint
D. Sensor
Show the Answer
Sensor
Question 23
A. When the system has no disturbances
B. When eliminating steady-state error
C. When long-term accuracy is not critical
D. When quick response is needed
Show the Answer
Question 24
A. Simpler design
B. Lower cost
C. Faster implementation
D. Combines proportional, integral, and derivative actions
Show the Answer
Question 25
A. Automated assembly lines
B. Temperature control in HVAC
C. Cruise control in cars
D. Manual traffic signals
Show the Answer
  • Types of Control Systems
  • Faults in PID Control Loop
  • Instruments in Flow Control Loop
  • Ziegler-Nichols Open-Loop Method
  • Process Control Loop Testing
Timers using Statement List (STL) PLC Programming
Heat Exchanger Temperature Control
What is DIN rail ?
Series Tanks Level Control using PLC Ladder Programming
Working Principle of Single Phase Preventer Relay
PLC vs PAC – Understanding the Key Differences and Similarities
Connecting Blocks in Functional Block Diagram – Studio 5000
How to implement SR Flip Flop using PLC Ladder Logic
Advanced PLC Programming for Defective Parts Sorting
What is RS Linx? Types of Software in Rockwell Automation
Valve Quiz
Five Levels in Industrial Automation
Fiber Optic Cable – Method of Joining and Fusion Splicing
Time Division Multiplexing Objective Questions
Ladder Logic of Motor Forward and Reverse
PLC Programming Example for Motor Forward and Reverse Control
Scan cycle of a Siemens PLC
OB1 – Main Cyclic Organization Block in TIA Portal
PLC attendance system design
Process Override Switch
What is Process Override Switch (POS)?
Hook-up Diagram for Pressure Gauge
What is Instrument Hook Up Diagram ?
Level Sensors MCQ
Level Sensors MCQ – Industrial Instrumentation
PLC Ladder Logic Chemical Mixing Process
Chemical Mixing Process using PLC
Difference between Compact PLC and Modular PLC
Sequential Operation of Output Bits using Two Push buttons
feed flow transmitter
Flowmeter Control Strategy
Beam-Detectors-Working-Principle-2
Beam Detectors Working Principle Animation
Circuit Breaker Control Circuit Wiring
Two-Liquid Manometer Principle
Digital Control Systems
Z & S Domain Relationship
Ammonia Gas Detector Calibration
Ammonia Gas Detector Working Principle and Calibration
Selection Criteria of PH Analyzer
