Reading: Communication Processor Module in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Communication Processor Module in Siemens PLC
Communication Processor (CP) Module is used to transfer the data in a case of not having the required port on your Siemens PLC CPU.
Last updated: March 4, 2021 11:14 am
3 Min Read
In this article, you will learn about the CP (Communication processor) module used in the Siemens PLC.
CP module is used to transfer the data in a case of not having the required port on your CPU.
For example, we have a redundant system installed in a plant. We have an S7-300 series of CPU 315-2DP is installed.
On the first rack, we have power supply and CPU is installed, the same way for redundancy one more CPU with power supply is installed.
On the second rack, two IMs are installed as you can see in the below window.
Now, both CPUs are communicating with IMs through the PROFIBUS-DP network.
But how the 1st CPU will exchange the data with the 2nd one? First, you may think of the second MP (Multi-Point Interface) to exchange the data.
But as you know MPI is a very slow network and it is not possible to send out a large amount of the data using this network.
If you use MPI to exchange the data then you only have to use the MPI network throughout the communication.
But I want to communicate or exchange the data in terms of the PROFIBUS-DP network.
To do that we have to install Simatic NET or CP having DP port on it into the rack beside the CPU as you can see in the below window.
As you can see by pulling one more PROFIBUS-DP cable with the help of the CP module and using some software arrangement you can exchange the data.
Siemens CP Module
The CP module which I have shown you contains a single DP port is a CP 342-5.
There are other types of CP modules that are used that depend on an application and requirement of the network.
Other CP modules for an example are,
* CP 342-5
* CP 1243-8
* CP 343-1
* CP 443-1
* CP 342-2
Below is the image of each type of module having a different capability of communication. (PROFIBUS-DP, Ethernet, ProfiNet, etc.)
Whatever module you use, the connection technique remains the same. only the way and speed of the data exchange will differ based on the requirement.
Author: Suhel Patel
  • Power Supply Circuits
  • Connect to the Siemens PLC
  • Digital Signals and Gates
  • What is the DDE Protocol?
  • Pulse Width Modulation
PLC Program for Daily Production Record
PLC Structured Text Program for Output Generation via Equations
Allen Bradley PLC Subroutines
Mail Box Automation: Programming with Schneider PLC
Sequential PLC Programming for the Pneumatic Valves
Comparator in PLC Programming
Advanced PLC Programming for Defective Parts Sorting
PLC Program for Positive Edge Pulse Output for One Scan Cycle
How to Filter Digital and Analog Inputs in a PLC?
What is NOR Flash Memory in PLC?
Ladder Rung with Two Outputs
PLC Multiple Outputs Configuration
Siemens CPU Clock Memory
Alarm Acknowledge using PLC
A typical wiring diagram from Field Transmitter to Control Room
How to Wire a Field instrument to Control Room with Example
How to use Scale and Normalize Instructions in PLC
D flip flop in PLC
D Flip Flop PLC Ladder Logic
Set the S5 timer value by a memory word
Set the S5 Timer Value by a Memory Word
JMP instruction in PLC Programming
How to use JUMP Instruction in PLC Ladder Logic?
Automatic Car Washing Process using PLC Ladder Diagram
Capacitive Pressure Transducer
Capacitive Type Pressure Transducers Principle
Pneumatic Actuators Types Animation
Types of Pneumatic Actuators Animation
Electrical Circuit Label Schematic
Label the Electrical Circuit Schematic
pressurized-water reactor
Runaway Processes
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
Advances in Control System
Fuzzy Logic Control
Mechanical Temperature Indicators (MTI) Problem
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
