Reading: Various Causes for PLC Going in Stop Mode
Inst Tools > Blog > PLC Tutorials > Various Causes for PLC Going in Stop Mode
In this post, we will see the various causes which change the PLC operation to stop mode and its common reasons.
Last updated: October 17, 2023 3:42 pm
In this post, we will see the various causes which change the PLC operation to stop mode.
Causes of PLC Stop ModeHardware ErrorSoftware ErrorRun/Stop Hardware Switch Run/Stop Digital InputMemory MismatchFull Downloading ProgramExternal Command from NetworkConclusion
A PLC basically has four modes of operation
  1. Run,
  2. Stop,
  3. Start-Up, and
  4. Hold.
The system on power-up starts by PLC going in stop mode. Immediately, it changes to start-up mode.
This mode can be said as a way for three paths.
In the first path, the PLC again goes to stop mode if an error is detected.
In the second path, it goes to hold or halt mode if any breakpoint in the program is reached.
In the third possibility, if everything is fine, then the PLC goes to run mode.
Basically, here we will see some common reasons on why the PLC will go into stop mode:
Hardware Error
If any hardware error is detected in the PLC configuration, then the PLC mostly throws an error indication.
But, if the fault is such that it can damage the PLC system, then it will go into stop mode. It varies from PLC to PLC.
Generally, any critical fault; like internal wiring short circuit or power interruptions in the  PLC modules forces it to go to stop mode.
But, if there is a case where the module is not connected in the configured program of PLC; then too the PLC will remain in run mode.
Only an error will be thrown. So, as long as there is no major hardware fault, the PLC will remain in run mode.
Software Error
If there are some software bugs in program; like unhandled exception, watchdog error, overflow error, underflow error, infinite calculations etc. then the PLC will go in stop mode.
A simple example is, if you divide anything by zero in the PLC program, then the PLC will not be able to execute the logic and it will go in stop mode.
Thus, any wrongly written logic, which doesn’t have any solution or end; causes the PLC to go in stop mode.
Some PLC’s have a hardware switch on it; which is a selection of run or stop.
It is a safety measure provided in case of an emergency. If this switch is in stop mode, then the PLC won’t go into run mode.
There are PLCs where you can assign a digital input to function as a run-stop switch.
That means, if this input is high, then only the PLC will function in run mode.
Memory Mismatch
In some PLC’s, there is a step to manually function a task to save the last done programming changes in the PLC memory.
If you do not do this task, and when you power reboots the PLC, then the PLC will go into stop mode.
In any PLC, full downloading a program causes the PLC to go into stop mode.
Nowadays, most of the PLC’s have the function of a web server embedded in it.
That means a programmer can access all the functions and configurations of the PLC by just entering the IP address of that PLC in the internet browser.
So, if that user has commanded stop logic from there, then the PLC will go into stop mode.
Conclusion
These are just the common examples. You need to always refer the diagnostic screen or variables of the PLC whenever you face such situations. It will be helpful in finding the exact cause of stop mode.
Author: Viral Nagda
  • Learn PLC in Hindi
  • PID Simulator Download
  • High-Speed Inputs in PLC
  • Pause the Timer Ladder Logic
  • Basics of Industrial Control Systems
Industrial Networking and Wireless Interview Questions
PLC Application for Stamping Operation – Example Programming
PLC Packing Machine Control System Program in XG5000
Getting to Know the LED Indications on GE Make PLC
Up Down Counter Instruction in PLC
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
What is Motor Jogging ?
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
Things to Take Care of When Designing SCADA System
How to Simplify PLC Coding Using Karnaugh Maps?
Timer in Studio 5000 – TON, TOF, RTO
100 PLC Quiz Questions : True or False
D flip flop in PLC
D Flip Flop PLC Ladder Logic
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Instrumentation During the Detail Design Phase
HMI
Comparison Instructions in PLC Programming
Open Platform Communication (OPC)
PLC Multiple Choice Questions
Leading Power Factor
Power Factor
Garage Door Roller Shutter
Why Fiber Optic Cable is Spliced rather than Termination
Why Fiber Optic Cable is Spliced rather than Termination?
Float Level Measurement
Types of Level Measurement
Vortex Flow Meter Principle
Vortex Flow meter Animation
Well Manometer Principle
Multimeter Digits
Multimeter – What Do Digits and Counts Mean?
Important Factors Consider during Piping Design
