Reading: Bently Nevada Vibration System Verification Procedure
Inst Tools > Blog > Vibration Measurement > Bently Nevada Vibration System Verification Procedure
Learn the verification procedure whether the Bently Nevada vibration and temperature protection system was installed correctly or not.
Last updated: May 3, 2023 9:54 am
vicky
3 Min Read
Bently Nevada proximity probe and transducer system is mainly used for measuring the vibration of equipment in the oil and gas industries.
This system is also used to measure the speed and temperatures of the equipment. This system is used to protect the equipment by continuously monitoring its vibrations, speed, position (of shaft), and temperature.
Different types of systems for vibration, speed, and position measurement are defined based on the length and size/diameter of the sensor probe tip. We will discuss about the most common system.
The vibration, speed, and position measurement system have 3 components installed in the field i.e. proximity probe, extension cable, and proximitor module.
Based on probe tip, different types are available, they are 5 mm, 8 mm, and 11 mm (most commonly used). Similarly, different lengths are also available like 1 meter, 5 meters, 7 meters, and 9 meters.
Now how will you identify whether the combination you are having is compatible or not?
Let’s have a look into it.
Suppose the following are the part numbers of 3 components installed in your plant.
Vibration Probe: 330904-08-15-10-02-IN
Extension cable: 330930-060-02-IN
Bently Nevada Extension Cable
Proximitor: 330980-71-IN
proximitor module
Now,
System length = Probe Length + Extension Cable Length
From the vibration probe part number, we can get the probe length by dividing the highlighted red number by 10 i.e. 10/10 = 1 meter in our case.
Bently Nevada System Length
Now from the extension cable part number, we can get the extension cable length again by dividing the highlighted red number by 10 i.e. 060/10 = 6 meters in our case.
Now as per the rule, System length = probe length + extension cable length, so system length should be 6+ 1 = 7 meters.
To verify the same, take the first digit of the highlighted red number from the part number of proximitor i.e. 7 in our case.
Here our system length is 7 meters and we also confirmed it by part number of proximitor as shown in the above image.
Also, the number highlighted in blue color should match in probe and extension cable part number as it is connector type i.e. 02 in our case.
This type of system verification will help us to cross-check whether the installed Bently Nevada vibration and temperature protection system was installed correctly or not.
What is TK-3 Calibrator ?
Vibration Probes Questions and Answers
Types of Sensors used in Vibration Measurement
Bently Nevada 3500 Machinery Protection Systems Hardware Modules
How Vibration sensors Work ?
  • Joyanta Mukherjee says:
    April 16, 2024 at 7:42 am
    Instruments Tool is immensely effective.
Vibration Switch Working Principle
Mechanical Vibration Switch Principle
What is Keyphasor ? How does Keyphasor works ?
Accelerometer Vibration Probe Principle
Interview Questions on Vibration Measurement
Proximity Transducer System Operation
Advantages & Disadvantages of Different Vibration Sensors
Vibration Analysis
Top 100 Vibration Analysis Questions and Answers
Guide to vibration severity per ISO 10816
Importance of Vibration Measurement
Eddy current Vibration Sensor Principle
Non-contact Vibration Measurement
hall effect speed sensor
Speed Probe Working Principle
Bently Nevada Proximity Probe
Root Cause Analysis for Vibration Probe Not Responding
Installation of Proximitor
Determine Lifting of Shaft using Proximity Sensor
LVDT Principle
Contact Vibration Measurement
Basics of Vibration Measurement
Counters Objective Questions
Integral Control Principle
Integral Controller Principle
What we need to Know before Tune a PID Controller
Sugar Industry Logics
Mill Interlocks in the Sugar Industry
Relay Parts
Difference Between NO and NC Contacts
Microprocessors Objective Questions – Set 2
Pressure Switch Construction
Basics of Pressure switches
Humidity Sensing Absorption Hydrometer Principle
