Reading: Bellows Pressure Sensors Working Principle Animation
Inst Tools > Blog > Animation > Bellows Pressure Sensors Working Principle Animation
Last updated: December 14, 2016 3:46 am
Animation How It Works Pressure Measurement
2 Min Read
Bellows Working Principle Animation
The bellows is a one-piece, collapsible, seamless metallic unit that has deep folds formed from very thin-walled tubing. The diameter of the bellows ranges from 0.5 to 12 in. and may have as many as 24 folds. System or line pressure is applied to the internal volume of the bellows. As the inlet pressure to the instrument varies, the bellows will  expand or contract. The moving end of the bellows is connected to a mechanical linkage assembly. As the bellows and linkage assembly moves, either an electrical signal is generated or a direct pressure indication is provided. The flexibility of a metallic bellows is similar in character to that of a helical, coiled compression spring. Up to the elastic limit of the bellows, the relation between increments of load and deflection is linear.
However, this relationship exists only when the bellows is under compression. It is necessary to construct the bellows such that all of the travel occurs on the compression side of the point of equilibrium. Therefore, in practice, the bellows must always be opposed by a spring, and the deflection characteristics will be the resulting force of the spring and bellows.
Phosphor Bronze, Brass, Beryllium Copper, Stainless Steel are normally used as the materials for bellows.
Bellows are manufactured either by
(i) turning from a solid block of metal, or
(ii) soldering or welding stamped annular rings, or
(iii) rolling (pressing) a tube.
Also See : Bourdon Tube Pressure Gauge Working Animation
Impulse Line – Purpose & Tapping Point Location
How to Measure Pressure in Inches of Water Column
Types of Pressure Measuring Scales
Cat and Mouse type Level Indicator
What is Hammer Effect in Gauges ?
Unbonded Strain Gauge Principle
Scintillation Counter Principle
Differential Pressure Transmitter with 5 Way Manifold Valve
Gage and Absolute Pressure Transmitters Principle
Level Indicators Working Principle
Thermocouple Working Principle
Two Wire Sensors Animation
Two Wire Sensor Working Principle and Animation
Absolute and Gauge Pressure
Difference Between Absolute and Gauge Pressure
Purpose of Stop in a Pressure Measuring Instrument
Differential Pressure Transmitter Question
Differential Pressure Transmitter Questions
Pressure Gauge Calibration Procedure
MOS Gas Sensor Principle
MOS Type Gas Sensor Principle
differential-pressure-transmitter-calibration-procedure
Differential Pressure Transmitter Calibration Procedure
Self Balancing Bridges Objective Questions
Bridge Circuits Objective Questions
100 PLC Quiz Questions
100 PLC Quiz Questions : True or False
Dew Point Meter Principle
Solid State Devices Objective Questions and Answers
Top 300 Solid State Devices Objective Questions and Answers
Batch Mixing with PLC Ladder Logic Program
Chart Recorders
What is a Recorder ?
VFD circuit
AC Motor Braking
Choked Flow of Control Valve
Choked Flow of Control Valves
